need help putting in a cam
Old Oct 8, 2004 | 08:44 AM
teal_civic_mobile's Avatar
Default need help putting in a cam
i have d15b jdm stockmotor with a mpfi swap on it
when i got the mpfi the guy gave me the si cam also
been wanting to put it in forever and i think tonights the night
i bought a skunk2 adjustable cam gear for 80$ last week and tonight i plan to put in on... any tips on putting cams in im new to this.. thanks teal_civic_mobile-PEace
Old Oct 8, 2004 | 08:50 AM
eumoria's Avatar
Default Re: need help putting in a cam (teal_civic_mobile)
yea, I also want to toss the D16A6 cam into my D15B
Is this a tricky install? I've never gone into an engine. Any special tools needed? Does it take some advanced knowledge?
Old Oct 8, 2004 | 08:58 AM
manson's Avatar
Default Re: need help putting in a cam (eumoria)
there are tons of how tos here on HT and google.
my suggestion for both of you is to buy a Helms manual and follow the instructions. Its not very hard, but there are bolt removal orders and tq specs to help make sure you do it correctly the first time.
I've done a few...b series... and my first time was pretty shacky, but a had help. im comfortable on my own now, but those books do really help.
Old Oct 8, 2004 | 10:38 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_civic_mobile &raquo;</TD></TR><TR><TD CLASS="quote">i have d15b jdm stockmotor with a mpfi swap on it
i bought a skunk2 adjustable cam gear for 80$ last week and tonight i plan to put in on... any tips on putting cams in im new to this.. thanks teal_civic_mobile-PEace</TD></TR></TABLE>
So you have a jdm D15B but you want to put a SI (D16Z6???) cam into it? Don't even do it...
Old Oct 8, 2004 | 10:39 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">yea, I also want to toss the D16A6 cam into my D15B
Is this a tricky install? I've never gone into an engine. Any special tools needed? Does it take some advanced knowledge?</TD></TR></TABLE>
You mean D15B7, correct? Then it's very simple.
Old Oct 8, 2004 | 11:57 AM
zephyr13's Avatar
some tips? well you have to lube the cams and the bearing covers and align the distributor and timing belt exactly how it was before you started working on it.
And the rest of the tools are pretty basic some of the tools you'll need are; a torque wrench, a 14mm wrench, and an 8mm wrench to take off the cam bearing covers.torque the cam bearing covers to manufactuarer's specs in your car manual.
Modified by zephyr13 at 1:04 PM 10/21/2004
Old Oct 12, 2004 | 08:04 AM
Default Re: need help putting in a cam (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai &raquo;</TD></TR><TR><TD CLASS="quote">
So you have a jdm D15B but you want to put a SI (D16Z6???) cam into it? Don't even do it...</TD></TR></TABLE>
why is that ??? any explanation please post back, curious...
it's a d15b its that it says on the block
Old Oct 12, 2004 | 08:07 AM
dr_latino999's Avatar
If it is the JDM D15B, i.e. the 1.5 liter SOHC VTEC motor, than there is no need to put a Z6 cam in there as the cam that came with your D15B is by far the best SOHC cam that came out of the factory for making power.
Time for lunch, have a nice day
Old Oct 13, 2004 | 08:59 AM
Default Re: need help putting in a cam (dr_latino999)
i have the d15b sohc no vtech
Old Oct 13, 2004 | 09:36 AM
91civicDXdude's Avatar
morons. all JDM 1.5L SOHC d series engines are D15B. they have carbbed non VTEC D15b's etc. etc. etc.
he wants to put his d16a6 cam into his JDM NON VTEC D15B. Its a very easy swap. You basically take the valve cover off and you can see all the bolts that will need to be removed to remove the old cam. A service manual will help out alot as some have mentioned
Old Oct 14, 2004 | 06:24 AM
Default Re: (91civicDXdude)
thank you!! i have a manual i was just wondering if u guys had any tips or how tos thanx for clearly up the situation -peace
F23hybridCd5
Jun 24, 2015 06:05 PM
titosek4
Aug 11, 2009 06:04 PM
hytec
Nov 25, 2005 08:55 PM
b18c1acura
Oct 11, 2004 11:31 AM
