hard start - help!!
Old Oct 8, 2004 | 07:20 AM
valve79's Avatar
Default hard start - help!!
I'm still new to this board i have 1993 accord stock every morning or when i let her sit for couple ours it takes two or three times to start it but when its hot it starts right up any clue ??? bump me yo. thanx luke
Old Oct 8, 2004 | 07:37 AM
hawkmgc's Avatar
Default Re: hard start - help!! (valve79)
I use to have that issue, but then I cannot say really which part caused it. I replaced my:
Fuel Pressure Regulator
Injector Resistor
O2 Sensor
Coil
and Cleaned out all the SLUDGE that was sitting in my intake from the Oil collection (otherwards known as blow by)
Seeing as I got this car used and was highly neglected. I am still putting this car back to where it should have been. At the rate this is going. I could have built a new one.
Old Oct 8, 2004 | 10:29 AM
br'Y'an's Avatar
hey i have the same problem i cant take any girls in it because it struggles to start if it stay there for a while. we need help
Old Oct 8, 2004 | 10:55 AM
Jay84ever's Avatar
Default Re: hard start - help!! (beatjunkie42)
Check the starter and igition.
Old Oct 8, 2004 | 01:59 PM
KatyHonda's Avatar
I would suspect marginal fuel pressure, perhaps the fuel filter needs replacement. Fuel pressure regulator might also cause the problem. Check that regulator vacuum line is in place and there's not a strong smell of fuel in the vacuum line. If yes, then replace regulator.
You could measure fuel pressure, if you have the fittings, but the fuel filter is inexpensive and if it's never been done, it's cheap and won't hurt anything.
good luck
svenglass
May 15, 2017 02:45 PM
mikeledez
Dec 8, 2009 08:30 PM
Jos3ph
Oct 19, 2008 12:09 PM
LScivic_wpg
13
Feb 9, 2006 01:49 PM
