Water pump question?
Old Oct 8, 2004 | 07:06 AM
meotch's Avatar
Default Water pump question?
hey guys, im planning on doin the timing belt, cam gears and water pump on the teg, i was just wondering if there are any other water pumps you would recomend other then the oem one, also i want to know if i should replace the belt tensioner too when i do the belt?
thanks
mitch.
Old Oct 8, 2004 | 07:32 AM
nek0's Avatar
Default Re: Water pump question? (meotch)
Just get the OEM...as for the belt tensioner, it's up to you. If the other belts are as old as your timing belt, just change them all while at it to save time & $.
Old Oct 8, 2004 | 07:45 AM
crazyteg95's Avatar
jdm pumps are better than oem, especially for the b18a if you have a GS-R or do you have an ls if you have an ls go ahead and get oem.
Old Oct 8, 2004 | 08:13 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
I've heard good things about the goodyear belts
Old Oct 8, 2004 | 08:24 AM
silvervlll's Avatar
stick with oem parts. and i would highly recommend replacing the timing belt tensioner
Old Oct 8, 2004 | 09:26 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Water pump question? (crazyteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyteg95 &raquo;</TD></TR><TR><TD CLASS="quote">jdm pumps are better than oem, especially for the b18a if you have a GS-R or do you have an ls if you have an ls go ahead and get oem. </TD></TR></TABLE>
say what? I couldn't follow that at all. I got an OEM Honda water pump for mine, it was made in Japan. Does that make it JDM?
I'm pretty sure all Integras world-wide use the same water pump, and I've never seen an aftermarket one, except just regular OEM-replacements.
Old Oct 8, 2004 | 09:42 AM
tegmech's Avatar
Those JDM pumps flow like 3 more gallons of water Yo. That shiz is mad tight. Good for like 20 hp. Even more if you put on the "JDM" sticker.
Old Oct 8, 2004 | 09:55 AM
IrishBrewer's Avatar
What specifically are you doing to the Cam gears, they shouldn't need to be replaced. You might want to order a set of seals for the cam gears in the event that they need to be replaced but no need to replace the gears - they're expensive.
Other things to change while you're at it include all of the accessory belts and your radiator hoses if they need it since you'll be draining the coolant anyway. Also, you could get a valve cover gasket set and swap those out while you've got the cover off. Get some hondabond sealant to coat the gaskets prior to installing them.
I didn't replace my tensioner when I did mine but many suggest doing it at the same time. Worst thing that can happen with that is a bearing goes out and I have to replace it later but I've heard some techs say that they've never seen one go bad.
Old Oct 8, 2004 | 10:10 AM
Community Builder
Default Re: Water pump question? (IrishBrewer)
I didn't replace either my water pump or tensioner at 90K miles, but I did change them both last weekend at 180K. The old ones still seemed fine, though.
I also replaced my cam seals, and those WERE nasty.
Old Oct 8, 2004 | 07:45 PM
boosted k20's Avatar
Default Re: Water pump question? (PatrickGSR94)
i just did my timing belt/water pump about 3 weeks ago when i installed my cams. i didnt replace the tensioner. also didnt use new valve cover gaskets or cam seals. the valve cover gasket was i ngood shape and they dont usually go bad. the cam seals were also in good condition. i just applied a seal of honda bond around them to ensure they seal up everything. No leaks in the motor so everything is hold n up pretty good.
and u dont need to replace the cam gear, unless ur get n adjustable ones. and there not that expensive too. i just threw mine away when i installed a set of SKUNK2 gears. u can proably get it on ebay for like 10 bucks a set used. but once again no need to replace the cam gears
Old Oct 10, 2004 | 06:59 PM
Community Builder
Default Re: Water pump question? (boosted k20)
I'm pretty sure the cam seals are not supposed to have hondabond or anything else applied to them, neither are the spark plug tube seals.
The valve cover gasket is supposed to have Hondabond only on the corners where they go up and over the cam caps.
92Snatch
Mar 14, 2014 09:19 PM
wasp9166
44
Mar 9, 2014 11:47 AM
siRone
May 9, 2009 08:26 AM
faSHOwidIT
Dec 2, 2004 08:41 PM
1ntensiveVTECivic
Dec 19, 2003 10:29 PM
