Help required in installing power lock in Honda Civic 1999
Hi all!
I have bought one power door lock kit to install it in my Honda Civic 1999 model.
Please suggest where should I take +12 volt supply from? Do I need to cut any wire and tap 12V from it or is there any available power socket where I can plug in to get 12V? I wonder if there is some standard harness/wire to draw power from, which might be having an appropriate inline fuse also in the fuse box.
Thanks in advance.
Thanks in advance.
i would get it from your ignition harness constant wire (12v constant) - its a thick guage wire, that is a good source for your power... i forget what color it is, but im sure you can look it up on da' web...
Yes, that is a white colored thick wire.
Any suggestions where should the central unit for power lock be placed in the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amit_bhar »</TD></TR><TR><TD CLASS="quote">Hi all!
Thanks in advance.</TD></TR></TABLE> All Hondas have a 12v conn. free plug on fuse box, use it, and mount unit around there.
94
94
jadugartir
May 22, 2005 01:26 PM
