Aftermarket support
Old Dec 14, 2001 | 08:35 PM
Tunerhead's Avatar
Default Aftermarket support
Aight,
I am installing an 89-91 B16 engine and wanna know, when I got to order aftermarket parts for my CRX, like CAI and exhaust, would I order them for the make and model of the car, or for the engine,
I'm confused on this topic,
thanks
I also wanna install a turbo on the B16, and once again for the make and model of the car, or the engine(I know engine).
Anyone know of a good size to install?
Thanks
I'm new to the CRX world so cut me a brake here
Old Dec 14, 2001 | 08:57 PM
Tunerhead's Avatar
Default Re: Aftermarket support (Tunerhead)
Another thing
is the B16A1 engine a good choice to install in my 91 Si?
What are all the availible engine that I can install?
I do wanna turbocharge it?
my friends at the other forum that I belong to said that the compression should be around8.5:1 or 7:1, is this true?
thanks for all ur help
Old Dec 14, 2001 | 09:17 PM
BIG RICH's Avatar
OK, you can order a CAI for a 99-00 civic Si, it works. You would order an exhaust for the car. Some turbo kit makers have turbo kits for CRX's with b16a's. yes the b16a is a fine choice for your car. As long as your running low boost(8-9 psi) you should be fine with your stock motor. You could probably go a little higher, but I don't know if I would. as for what other motors you can install in your car, well theres the ZC, b17a, b18a/b, b18c, b18c5, b20b, etc. there are more, but I'm tired right now. try http://hybrid.honda-perf.org
Old Dec 14, 2001 | 10:07 PM
Blown90hatcH's Avatar
Default Re: Aftermarket support (BIG RICH)
7:1 compression...no no. Your comprss of the B16a is 10.2:1. An LS swap might be a better choice for you if you want to boost it
Old Dec 15, 2001 | 01:51 PM
rioninja's Avatar
Default Re: Aftermarket support (Blown90hatcH)
Yeah, 7:1? WTF? thats way too low bro, i personally wouldnt go lower than 9:1. Even the B16as 10.x:1 can be safely turbo'd, but if you running more than moderate boost your gonna want to upgrade the internals anyways, no matter which engine you chose.
Old Dec 15, 2001 | 01:52 PM
rioninja's Avatar
oops, didnt read BIG RICH's post. good info
Old Dec 16, 2001 | 05:54 PM
Tunerhead's Avatar
Wouldnt anything bigger than a B16a be big and hard to fit into the CRX engine bay??????
Also, WIll the B16a2, or sec. gen. B16 engine, work in my CRX?
IF so, what are some of the differences, and would it be practical for my purposes?
I was thinking about running 10 psi boost on street and 15-20 psi boost on the track with the use of a boost controller.
Is the B16a1 engine a good choice?
Yes, I do plan on upgrading the internals, so I dont think boost is really an issue here. And of course, I do plan on reinforcing the internals before I install the motor into my car, so that takes alot of headaches away?
thanks in advance everyone
[Modified by Tunerhead, 5:27 AM 12/17/2001]
da_coolest
Jul 15, 2009 07:40 AM
93 ls
Oct 3, 2007 07:13 PM
theharlequin
Jan 17, 2006 02:42 PM
manwezy951
Apr 5, 2005 01:56 PM
Eckz2k
Jul 17, 2003 04:41 PM
