Electrical Gurus. Wire Harness Completely Hacked Just Before ECU. HELP
Well my car was recently vadalised
https://honda-tech.com/zeropost...15141
Well I got the car towed back to me this evening just before work.
The sugar was no problem, wasnt to pissed I guess after I was assured it could be fixed.
But I saw the carpet had been pulled up and my main wire harness had been cut probably 3 inches before me ECU!!!!!!
They cut all 3 clumps of wires cleanly, now seriously,... who that ******* sick, just unclip the ecu ********.
Now is this fixable? My battery was still coneccted when this happenned so I dont know if that meeses anything up.
But what I wanna know is can I just go find another Honda, cut that harness off and wire it all back together. Like is every wire different and has its own color in the loom or is it impossible to tell. Like I suck at wiring.
Or is there a way I can disconnect the haress somewhere else and just replace it with one from another Honda. now I dont wanna go pulling wires of the dash and cluster and all that **** because I will **** it up.
Let me know
Also what type of Honda would it have to be?
My car - 88 Crx Si (origianally from canada if it matters), d16a6, OBD0
Thanks
And yes- IM ******* MAD
Modified by 1 Cam Wonder at 9:54 AM 10/9/2004
Let me know
Thanks
Just go to the junkyard and cut off the section they cut off from an 88/89 Si.
You may be able to use 88-89 Si but I think there were wiring changes starting in the '90 year.
Very simple, just time consuming. Just get a lot of heat shrink tubing and solder it back up.
Or you can just replace the whole harness out of another car if you don't feel like doing the wiring. It'll be a lot more involved though.
You can probably do the wiring in about 25 minutes if you know how to solder.
My wisdom teeth were taken out @ 2pm today, Im droolin as I type, hurts so much but I had to get up for a bump
Someone bump this **** while I go back to bed please
Tylenol 3
Sticky Green
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder »</TD></TR><TR><TD CLASS="quote">
Tylenol 3
Sticky Green
Bump it for what? I already told you what to do.
I don't understand why people bump certain things
And yes, wisdom teeth suck. I got all 4 of mine pulled at the same time
Tylenol 3
Sticky Green
</TD></TR></TABLE>Bump it for what? I already told you what to do.
It might be easier Just to replace the whole harness. Not to mention you wont have any electrical problems. I know i would feel better with a new harness. One less problem Later on down the road.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">
Ummmm because I was told this way going to be very difficult and that wires were going to be the same colours and ****, and I need to know what cars I can remove them from....
Theres a lot of wrongful info on these boards that Ive been reading so I definetely will never take the first opinion I get to heart so.......
<FONT SIZE="20"> B U M P</FONT>
</TD></TR></TABLE>Ummmm because I was told this way going to be very difficult and that wires were going to be the same colours and ****, and I need to know what cars I can remove them from....
I'm not trying to be mean, but you really have no use bumping this still.
Cut off the ECU wires from a junkyard car and solder them to what's remaining in your harness.
Even if some of the wire colors are different, the pin locations are the same so it does not matter.
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">I'm not trying to be mean, but you really have no use bumping this still.
then i will bump for him
sorry bout that **** man and yes wisdom teath suck
Tell you what. I'm going to make it as easy as humanly possible.
Go look at the junkyards until you find an '88 Crx Si.
Cut off the ECU harness and then solder into yours. All the colors will match, and you'll have no worries at all.
I'm 99% sure that the 88/89 Si used the exact same harness and pin locations. Maybe one of the CRX guys will chime and say for certain.
You're stressing over an issue that is actually pretty simple.
This would be very Similar to a MPFI swap. Hell And that was easy. Really it cant get any more fucked up. Just go to the jukyard and cut on off. and wire that **** up. The more time you spend bumping this **** the more down time you have on youre car.
lol dont think Im sitting here when I could be working on the car.
The car is 40 miles away at my grandparents, my wisdom teeth were just removed and Im babysitting my sister until sunday night, then I have thanksgiving dinner and on Monday will the only day Ill have to do this
Just making sure Im not gonna hit a snag and not be able to drive my sis to school and get my *** safely to work tuesday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">I'm not trying to be mean, but you really have no use bumping this still.</TD></TR></TABLE>
and you have no use reading it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 »</TD></TR><TR><TD CLASS="quote">
I always check in on threads I've replied to should there be more questions.
But when something has been answered and I just read 'bump' 'bump' over and over I'm mainly curious as to why.
</TD></TR></TABLE>I always check in on threads I've replied to should there be more questions.
cr00klyn718
Jul 13, 2003 10:59 AM
greebler
May 12, 2003 10:53 AM
