burning out
Old Oct 7, 2004 | 08:28 PM
red_crx's Avatar
Default burning out
i have a crx w/ b16 and i tried to do a 2nd gear burnout but nothing happened; it just bogged.
This is what i did: 1. pulled the e-brake
2. revved to 45k and theneven tried 5k
3. dropped the clutch and nothing
What could be the problem; do i not have enough power or do i need to rev higher?
Old Oct 7, 2004 | 08:31 PM
crxdx89's Avatar
2nd gear?????????????
Old Oct 7, 2004 | 08:34 PM
mrspeaker's Avatar
Default Re: (crxdx89)
Why would u try to do a 2nd gear burnout??...Are u tryin to burn ur clutch????
Old Oct 7, 2004 | 08:35 PM
EVOLUTIONINNYC's Avatar
you have to rev to 7k then slide your foot off the clutch pedal so it realeses fast as ****
Old Oct 7, 2004 | 08:44 PM
Loaded Butane's Avatar
Maybe he used 2nd gear to hit mad tizzite vtec y0 for extra tire/clutch melting power.
Old Oct 7, 2004 | 08:46 PM
red_crx's Avatar
Default Re: burning out (red_crx)
Just decided to give a try since i saw someone do it before. Looks like i'll stick to the 1st gear burnouts.
Old Oct 7, 2004 | 08:47 PM
You must not pay for your tires.
Old Oct 7, 2004 | 08:51 PM
Origin's Avatar
Default Re: (Loaded Butane)
i wish someone would pay for my tires
Old Oct 7, 2004 | 08:55 PM
red_crx's Avatar
I was using some old tires on steelies that my cousin had lying around
Old Oct 7, 2004 | 09:01 PM
riceisnicenv's Avatar
Default Re: (red_crx)
i thought second gear burnouts were supposed to conserve your spider gears or something that are associated with first gear. i heard about this in the drag racing forum a little while ago. someone post up some REAL info...
Old Oct 7, 2004 | 09:06 PM
BiG Chris's Avatar
start your burnout in first then shift to second then if you can 3rd
Old Oct 7, 2004 | 09:22 PM
Redline130's Avatar
Default Re: (BiG Chris)
At the track, I do my burn-outs in 2nd gear. I rev it up to about 6500~7K and just dump the clutch. I've been told that doing the burn-out in second gear isn't as harsh on the tranny as doing it in first. I've also noticed that it doesn't take as long to get the slicks heated up as it would in first. Dump the clutch, a few seconds of burn-out and the slicks start grabbing and pulling you forward.
Old Oct 8, 2004 | 08:12 AM
wompwomp61's Avatar
haha, yea burnouts. i had quite the ordeal last week with that. got flamed for a friends idiocy.
Old Oct 8, 2004 | 08:56 AM
Brownjd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_crx &raquo;</TD></TR><TR><TD CLASS="quote">i have a crx w/ b16 and i tried to do a 2nd gear burnout but nothing happened; it just bogged.
What could be the problem; do i not have enough power or do i need to rev higher?</TD></TR></TABLE>
wow! 45k rpms! you should try a 5th gear burnout
Old Oct 8, 2004 | 09:44 AM
FalkenSiR's Avatar
Default Re: burning out (Brownjd)
i didn't know B16s revved up to 45.000 rpm
just j/k
wet those bitches
Old Oct 8, 2004 | 09:47 AM
kaoss_11's Avatar
B A N N E D
i only do burnouts in rentals. too much money to replace tires and that heats up your clutch and tranny especially in 1st
Old Oct 8, 2004 | 10:57 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">i only do burnouts in rentals. too much money to replace tires and that heats up your clutch and tranny especially in 1st</TD></TR></TABLE>
:homer simson: " it's like a rental car son, get all the milage u can then cram it up and jam it though the mail slot"
none of the rental agenceys have stick cars so i have to settal for my dad's 220HP 206 FT touque tacoma truck but dont tell him some times i shift in to 4WD and try to do a 4-way burnout neverbeen susfull
@Diego
19
Jun 27, 2012 09:31 AM
FuNkDrSpOt
15
Oct 15, 2007 03:03 AM
98_civic_dude
Jun 6, 2005 01:07 PM
eMpAtHy
Apr 18, 2005 12:39 AM
ITR111
Mar 15, 2002 06:09 AM
