Can HID bulbs be repaired?...
Old Oct 7, 2004 | 08:17 PM
chuckus's Avatar
Default Can HID bulbs be repaired?...
One headlight wasnt working, so i pulled it out of the socket and saw this...
anything that can be done, do they sell bulbs by themselves??
-Carlos-
Old Oct 8, 2004 | 06:53 AM
chuckus's Avatar
Default Re: Can HID bulbs be repaired?... (chuckus)
morning bump
Old Oct 8, 2004 | 07:51 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuckus &raquo;</TD></TR><TR><TD CLASS="quote">One headlight wasnt working, so i pulled it out of the socket and saw this...
-Carlos-</TD></TR></TABLE> No it can't be fixed, yes they sell bulbs. 94
Old Oct 8, 2004 | 08:26 AM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: Can HID bulbs be repaired?... (fcm)
that really shouldnt affect it... i had a bulb like that, and it still worked... i think that the peice that is broken is just a guard/sheild... something else is probably wrong with it...
Old Oct 8, 2004 | 08:41 AM
Odessa's Avatar
Default Re: Can HID bulbs be repaired?... ("Fresh Pizza Guy")
May be the contacts are bad or the ballast is dead? Try to put it on the other side and see...
Old Oct 9, 2004 | 05:51 AM
rjr162's Avatar
Default Re: Can HID bulbs be repaired?... (Odessa)
I think that wire powers the other half of the bulb, kinda like overhead floresent lights have power feeds on both ends.
Old Oct 9, 2004 | 07:07 AM
Default Re: Can HID bulbs be repaired?... (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">I think that wire powers the other half of the bulb, kinda like overhead floresent lights have power feeds on both ends.</TD></TR></TABLE>
nah, im pretty sure is a shield over the wire that powers the bulb...
Old Oct 9, 2004 | 07:21 AM
rjr162's Avatar
er just noticed that was only the covering... I took a quick glance (2nd pic) and it looked like the wire itself snapped.
Old Oct 9, 2004 | 02:53 PM
philadd's Avatar
the broken piece is made of porcelain, and it covers/shields the ground wire. it also keeps the voltage from jumping from the bulb to the headlight housing. typically, when's it broken, the bulb will not work anymore. it was my understanding that when the power jumps instead of completing the circuit, the ballast simply shuts off.
so... you'll need to replace the bulb...
Old Oct 10, 2004 | 08:34 AM
chuckus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odessa &raquo;</TD></TR><TR><TD CLASS="quote">May be the contacts are bad or the ballast is dead? Try to put it on the other side and see...</TD></TR></TABLE>
You were on the money there...
I just bypassed that connector with a butt connector, everything works fine now. I guess that "myth" about HID's created too much heat has just been busted.
Da1Gsr
Mar 6, 2006 07:03 PM
SuicideSlide
Dec 20, 2004 03:25 PM
DieMaster
Oct 27, 2004 09:24 PM
Tommy_Gunns
Oct 24, 2003 03:59 PM
rizen
Aug 21, 2003 02:13 PM
