'04 Accord radio removal
What's up guys, I'm new to the site, and new to Honda as well. I just sold my '02 nitrous/cam Camaro SS for an '04 Accord, and to tell you the honest truth, apart from power, I like the Accord MUCH better.
With that admitted, I'm looking to install subs and two amplifiers, and need to get to the back of my factory head unit (which will not be replaced). I just need to know what to take apart to get it out. Removal instructions would help a BUNCH!
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realdealcamss »</TD></TR><TR><TD CLASS="quote">What's up guys, I'm new to the site, and new to Honda as well. I just sold my '02 nitrous/cam Camaro SS for an '04 Accord, and to tell you the honest truth, apart from power, I like the Accord MUCH better.
Thanks!</TD></TR></TABLE>link http://www.installdr.com
94
94
I looked at that site, but could not find any info for the '03/'04 generation. The newest I could find is 1999-2000. Is there a specific link you could give me?
And I know at least SOMEONE here has taken their factory deck out.... help!
Thanks
Thanks
hey, i'm in sorta the same boat. this guy's site has been the closest thing i've found. basically shows you how to get to under the head unit, but not to take it out. basically take off shifter console trim, undo screws. take out coinholder/cig plug. undo screws. remove lower storage compartment, but then...??
http://members.aol.com/hillsto....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realdealcamss »</TD></TR><TR><TD CLASS="quote">I looked at that site, but could not find any info for the '03/'04 generation. The newest I could find is 1999-2000. Is there a specific link you could give me?
Thanks</TD></TR></TABLE> Sorry did not know it was not updated to 04 yet, the only other ones I know of I have to access at work, can let you know tonight.
94
94
it is really hard to remove the factory deck in those cars... when i worked at best buy we used to dread removing them... i would personally take it to a shop and avoid the headache and possibility of cracking something
freshpizzaguy, so is it possible to remove the deck without disturbing the air conditioning(etc) controls? i didn't think you could do that, but from your post it sounds like maybe it can be done??? at least by a shop? i'm curious!
the factory radio is one piece u cant loose the radio wit out the ac. i got my 03 accord the aftermarket hu was installed where the cd holder is located at the lid part.
check into PAC... I think it was them.... One of those companies now make a High -> Low level converter that not only takes the high level to low level, but you also connect a wire to your amps +12 constant, and the High Low adaptor has a circuit that reads when the speaker lines are "active" and has a 2nd wire that works as a remote turn-on output.
This would be the easiest way to go since you could just tag off of the rear speakers.
Thanks!</TD></TR></TABLE> To remove pocket below radio.
1- Gently pry up to remove shift trim bezel.
2- Openashtray/small storage pocket. Remove pocket. Extract two screws from pocket opening. unplug and remove assembly.
3-Extract two screws from lower part of large dash storage pocket. With pocket door closed pull toward shifter to unsnap clips and remove.
4- Extract two 8mm bolts from under radio assembly brackets.
Continue to remove factory radio
5- From above radio assembly gently pry out on vent/hazard panel.Continue along both sides of panel, gently releasing clips. Lift up, unplug, and remove.
6- Extract three screws from top of radio assembly. Pull toward shifter to unsnap clips. Unplug and remove.
This is word for word from Scosche on how to remove OEM radio from 2003 and up Honda Accord,[lower dash pocket ]vehicles. off the Scosche HA-1573 kit
Sorry it was all I could find.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> To remove pocket below radio.
94</TD></TR></TABLE>
That is excatly how to do it. The cubby hole is a PITA, and the vents atop the HU are a PITA. Go slow, it takes a little time to pull it out.
94</TD></TR></TABLE>That is excatly how to do it. The cubby hole is a PITA, and the vents atop the HU are a PITA. Go slow, it takes a little time to pull it out.
speedbreaker
10
Aug 16, 2006 05:38 AM
