CAN'T FIND SENSOR
Old Dec 14, 2001 | 06:18 PM
allmotorEG-SI's Avatar
Default CAN'T FIND SENSOR
My ecu keeps throwing a code for some speed sensor. I think its the vss or vcc, somthing like that. But its also the reason my speedometer doesn't work anymore. My mechanic said he accidently cut a wire when installing my tranny but anyhow to the question. Where is the damn thing. I look and look and can't find that stupid sensor. Any help would be greatly appriciated.
Old Dec 14, 2001 | 07:34 PM
Kamin's Avatar
Default Re: CAN'T FIND SENSOR (CAMAROCRUSHER)
your mechanic needs to "accidentally" get a kick in the *****. make his *** fix it
ok the VSS is located on the top of the tranny back (firewall) half. its a connector that has 2 wires comming off it
obviously trace them as far as you can to find where they were cut.
Old Dec 14, 2001 | 08:17 PM
civicturbo's Avatar
It's also black in color and is plastic. It's about 4 in. long with only about 2 in. visible. (half of it is in the tranny).
Old Dec 14, 2001 | 09:53 PM
TECH43 RACING INC.'s Avatar
Default Re: CAN'T FIND SENSOR (civicturbo)
ACTUALLY.....IT HAS A THREE PIN WIRE HARNESS AND PLUG...NOT TWO
Old Dec 14, 2001 | 10:36 PM
Kamin's Avatar
Default Re: CAN'T FIND SENSOR (TECH43 RACING INC.)
caps lock my friend
learn how to use it.
and if it is 3 my bad. im going on about 3 hours of sleep right now and that was from memory.
Old Dec 15, 2001 | 04:49 AM
rainforest's Avatar
Default Re: CAN'T FIND SENSOR (KAMiN)
you could allways just use a wire repair kit and crimp the wires together and not buy a new vss. Also is your car cable tranny because the easy way to fing it on a cable tranny is to trace the spedo cable to it.
Old Dec 15, 2001 | 12:37 PM
Kamin's Avatar
Default Re: CAN'T FIND SENSOR (rainforest)
**** yea
dont waste money on a new vss
butt connectors and electrical tape.
big-cat
Mar 17, 2008 11:55 AM
Darth_Accord90
Mar 7, 2007 01:54 PM
platinumx6
Dec 29, 2006 07:49 AM
mike93eh
Sep 29, 2005 02:01 PM
veilsides2000
Nov 5, 2004 10:52 AM
