Code 15: Ignition Output Signal
Old Oct 7, 2004 | 04:09 PM
Brett420's Avatar
Default Code 15: Ignition Output Signal
I get this error code and my car won't turn off. I've changed the entire igntion, wiring harness under dash, and key cylinder. The way i turn my car off is to pull the alternator fuse, after turning the key off, shuts it down in 2secs. If if pull it with the key on it stays running. 91 civic hb B16A1 NA, PR3 ecu.
Old Oct 8, 2004 | 02:36 PM
Brett420's Avatar
Default Re: Code 15: Ignition Output Signal (Brett420)
bump
jchrm80
Dec 20, 2007 12:41 PM
CiViC SiR
Jul 4, 2003 02:24 PM
