Why does my engine Rumble when i shut it off?
when i turn off the car it goes droom droom drum! lol like it shakes and sputter, studders whatever it doesnt should nice and feel nice
help please!
help please!
If its continuing to run after you turn the key off, then I believe its called "dieseling" and its because of carbon buildup in the cylinder continuing to ignite fuel after the ignition is turned off.
If thats not it, then I have no clue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl »</TD></TR><TR><TD CLASS="quote">Sea Foam
damnit bro, you beat me to it..
to orig. poster. go into search and type in "seafoam" and check it under both archived and recient content.. i know theres a big *** thread, maybe even two big *** threads that have been archived.. so check it out bro
</TD></TR></TABLE>damnit bro, you beat me to it..
yo ya i've read that one a few months ago. is that the only way b/c some people said it isnt good b/c it clears up areas of the motor where u might lose compression or create leaks. i dont know. it didnt sounds 99% safe. just worrying i guess but i have to integras and the other is fine so i guess i should just try it. just the teggy with the problem looks nicer then the other
ohh well my problem. more info people please more info!
From: Formerly of SF moved to DFW and now back in SF, CA, USA
When's the last time you changed your cap, rotor, wires and spark plugs? Maybe it's time.
I've done Sea Foam on 4 cars so far and it's been great every time. Just follow the directions and you'll be fine. After about 1/3 in the intake manifold vacuum hose (via the brake booster vacuum hose) I put the rest in the gas tank.
a way to get rid of carbon build up is water.
get a few ounces and put it in a spray bottle. spray 2-3 times every minute and rev it up. do it a few times. if u have some 1 do it and u go to the back u can see the carbon fly out. BUT DO NOT SPRAY TOO MUCH WATER OR DO IT FOR MORE THEN 5 MINUTES. it will **** up ure engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteGSR95 »</TD></TR><TR><TD CLASS="quote">a way to get rid of carbon build up is water.
get a few ounces and put it in a spray bottle. spray 2-3 times every minute and rev it up. do it a few times. if u have some 1 do it and u go to the back u can see the carbon fly out. BUT DO NOT SPRAY TOO MUCH WATER OR DO IT FOR MORE THEN 5 MINUTES. it will **** up ure engine. </TD></TR></TABLE>
why risk that when you have a product that guarantees the job?
not smart :hammerhead:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DriveSideWays »</TD></TR><TR><TD CLASS="quote">ok ok ill try the sea foam. i hope it has instructions. plus i can search for the past seafoam thread. it was huge. and yes i've changed the cap, rotor and plugs a few months ago</TD></TR></TABLE>
Here is a article from team integra
http://www.team-integra.net/se...D=972
User 42624
Jul 4, 2007 10:20 AM
