88 CRX shocks/suspension
Old Oct 7, 2004 | 01:10 PM
Reelizmpro's Avatar
Default 88 CRX shocks/suspension
Alright 88's have a unique suspension that shares some rear parts with the ITR. My question is what shocks are available for the 88's? KYB AGX? Koni?
Old Oct 7, 2004 | 01:13 PM
Tyson's Avatar
Default Re: 88 CRX shocks/suspension (Reelizmpro)
theyre all available. just different part numbers. ITR doesnt "share" parts, its just similar design.
Old Oct 7, 2004 | 01:28 PM
eda6's Avatar
Default Re: 88 CRX shocks/suspension (Tyson)
You can't get agx for the rear with your lca's. If you want agx in the rear get 89-91 lca's.
Old Oct 7, 2004 | 01:51 PM
notfastenough's Avatar
Default Re: 88 CRX shocks/suspension (eda6 hatch)
I'm sure you can use agx's in the rear if you use the itr shock. I used tokico's on my 88. Good luck
Old Oct 7, 2004 | 09:19 PM
BOSS-REX's Avatar
Remember that the bottom shock mounts are different than the later model CRXs the 88s mount inside the link the later models mounts rap around.
On my 88 CRX I have tokico shocks the adjustable ones and they ride firm.
Old Oct 8, 2004 | 05:14 AM
88 rex's Avatar
Default Re: 88 CRX shocks/suspension (BOSS-REX)
Koni has externally or internally adjustable rear yellows for 88's. You can pick up internally adjustable for really cheap. I got my rears for about $100. Front are all the same i think.
Old Oct 8, 2004 | 08:38 AM
Reelizmpro's Avatar
Default Re: 88 CRX shocks/suspension (88 rex)
I've read that the front shocks on 88's are somehow slightly different...perhaps smaller?
Old Oct 8, 2004 | 08:51 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">I've read that the front shocks on 88's are somehow slightly different...perhaps smaller? </TD></TR></TABLE>
The 88-91 front shocks are all the same. The 89-91 rear shocks are all the same. The 88 rear shocks are the outcasts, they are different.
Old Oct 8, 2004 | 08:55 AM
newaccordguy2003's Avatar
what makes them different?
Tyson's Avatar
Default Re: 88 CRX shocks/suspension (EL Vap133)
actually, for some reason, the 88 front shocks do have separate part numbers. im not sure why, but theres something to it, even tho they all might fit between the years.
Old Oct 8, 2004 | 08:58 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">actually, for some reason, the 88 front shocks do have separate part numbers. im not sure why, but theres something to it, even tho they all might fit between the years.</TD></TR></TABLE>
Maybe because they sell them in sets. Look around and you'll see other places that list them with the same part #'s.
Old Oct 8, 2004 | 08:59 AM
EL Vap133's Avatar
Default Re: (newaccordguy2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newaccordguy2003 &raquo;</TD></TR><TR><TD CLASS="quote">what makes them different? </TD></TR></TABLE>
The 89-91 shocks have like a fork-like way of mounting itself on the LCAs. The 88 shocks go into the LCA.
For example, the shocks on the right would fit any Honda with LCAs like the 88 crx stlye:
Old Oct 8, 2004 | 09:15 AM
Tyson's Avatar
Default Re: (EL Vap133)
Tokico Illumina Adjustable Struts and Coil-over Shock Absorbers:
89-91, Front, BU2797A, $109.48
BU2798A, $109.48
89-91, Rear, BU2847, $109.48
88, Front, BU2797, $107.37
BU2798, $107.37
88, Rear, BU2799, $109.48
Old Oct 8, 2004 | 09:24 AM
89civicdx's Avatar
I THINK it has something to do with the front brakeline bracket...but I'm not positive.
Otherwise the length is the same.
Old Oct 8, 2004 | 09:30 AM
EL Vap133's Avatar
Default Re: (Tyson)
BU2798A, $109.48
BU2798, $107.37
88, Rear, BU2799, $109.48 </TD></TR></TABLE>
Well, get ready to shrug again:
1988
Shock Absorber AGX
L4000-64379 KYB $190.36 $116.15
Description: Front-Right
1989
Shock Absorber AGX
http://www.autopartswarehouse.com/
Old Oct 8, 2004 | 09:38 AM
89civicdx's Avatar
front brake line bracket I believe the kyb's come with a extra plate adapter for the lines
http://www.jcwhitney.com/autop...10102
http://store.summitracing.com/...03641
Old Oct 8, 2004 | 09:41 AM
Reelizmpro's Avatar
Damn very confusing. Sometimes when there's an outcast, shops/stores unknowingly group them all together...it's very common with BMW as well. The difference between the front shocks 88 vs 89-91 is probably minor anyway. I know i read that the diameter is different but not sure if that's accurate.
Old Oct 8, 2004 | 09:43 AM
EL Vap133's Avatar
Default Re: (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">Damn very confusing. Sometimes when there's an outcast, shops/stores unknowingly group them all together...it's very common with BMW as well. The difference between the front shocks 88 vs 89-91 is probably minor anyway. I know i read that the diameter is different but not sure if that's accurate. </TD></TR></TABLE>
They're the same, size and all, fronts that is.
Old Oct 8, 2004 | 09:45 AM
Reelizmpro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
They're the same, size and all, fronts that is. </TD></TR></TABLE>
Ok but why would companies bother giving them separate part numbers and different pricing?
Old Oct 8, 2004 | 09:52 AM
ah, now i see. i had always heard that the 88's were different, but i never knew why. thanks El Vap.
Old Oct 8, 2004 | 09:54 AM
Tyson's Avatar
Default Re: 88 CRX shocks/suspension (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">
actually, im thinking this is probably the reason. the 89-91 front kit comes with the odd brakeline adaptor for each side, which im thinking to a manufacturers point of view, the addition of any extra part to a kit requires a different part number, yet the subtle difference in part number reflects the minor addition to the kit.
Old Oct 8, 2004 | 09:58 AM
89civicdx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">Ok but why would companies bother giving them separate part numbers and different pricing? </TD></TR></TABLE>
They do this because they have to assume you have very little mechanical ability and they want their part to bolt right in for you. They don't want you calling them bitching about something that doesn't work
You can make anything work though if you put some thought into it as these are minor details.
Old Oct 8, 2004 | 10:10 AM
EL Vap133's Avatar
Default Re: (89civicdx)
LOL, basically, yes.
Old Oct 8, 2004 | 07:41 PM
Jester88Si's Avatar
I have 91 DA front shocks on my 88 crx and they work/fit fine..... the rear ones however have to made for an ITR or specifically for a 88 rex
aw614
Suspension & Brakes
May 12, 2013 01:52 PM
t0ekn3e
Suspension & Brakes
Jan 5, 2007 05:09 PM
LillDragun
Feb 8, 2003 12:05 PM
Civic44
10
Dec 30, 2002 09:21 AM
Bumnah
Jan 3, 2002 06:21 PM
