NEED HELP MSD SPARK PLUG WIRES
Old Oct 7, 2004 | 12:41 PM
shoei's Avatar
Default NEED HELP MSD SPARK PLUG WIRES
Hi guys,
I had a 2001 Integra GSR and i`m planning to change the spark plug wires for my car. I was wondering which is better, MSD or NGK. MSD is a little bit costly, but i don`t know which is best for my car. and what actually does the spark plug wires do, i know it prevent crossfire, but any special advantages
thanks for all your help
Old Oct 7, 2004 | 12:48 PM
dip-set's Avatar
Default Re: NEED HELP MSD SPARK PLUG WIRES (shoei)
your not gonna have any edge using one or the other, oem wires are good enough,or even ngk,but if your like me,i want red wires just to complete my engine bay color scheme,cause my blue ngks and my red/black scheme clashes
Old Oct 7, 2004 | 01:02 PM
iixerOii's Avatar
Default Re: NEED HELP MSD SPARK PLUG WIRES (b18b-se)
I have the NGK premium blues with NGK platinum plugs and they work fine for me. As for an explanation to what spark plug wires do try this link.
http://auto.howstuffworks.com/ignition-system.htm
Old Oct 7, 2004 | 03:40 PM
PlastikOwl
Guest
Posts: n/a
Default Re: NEED HELP MSD SPARK PLUG WIRES (iixerOii)
Just stick with OEM. There's really no point in any kind of special wires if you're not running an external coil.
Old Oct 7, 2004 | 03:58 PM
LSvtec03's Avatar
Default Re: NEED HELP MSD SPARK PLUG WIRES (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">Just stick with OEM. There's really no point in any kind of special wires if you're not running an external coil.</TD></TR></TABLE>
Old Oct 7, 2004 | 04:01 PM
..::91TEG-G2::..'s Avatar
also it can sometime's cause more complications with firing then it would if you had oem.
and plus, bigger ignition kits are used for turbo app's and stuff like that, or big all motor app's cuz it helps burn the big consumption of fuel you need to make the big power
Old Oct 7, 2004 | 04:03 PM
EL Vap133's Avatar
NGK's are the way to go, if not OEM.
EtchaSketch
Jun 21, 2005 11:42 AM
POWERINTEGRA
Jan 18, 2005 12:34 PM
ASpec818
11
Jan 2, 2005 05:29 PM
CivicEsEye
16
Jan 1, 2002 08:29 AM
