fuel pressure gauge
i have a 97 accord with a jdm h22 and im looking for a fuel pressure gauge, do i buy one for my accord or the h22. most gauges go on the fuel filter but the accord one is all the way at the bottom. is there a company that makes one where it will fit on the fuel pressure regulator?
You have basiclly 2 simple options.
1. Would be to get an electronic fuel pressure gauge and fitting adaptor for the sending unit to sit on the top of fuel filter.
2. Would be to install an AEM fuel rail witch has an extra port for the sending unit built into it. Or you can screw a gaauge right into the rail.
or just run a banjo bolt in the line, i had mine one for almost two years now and it reads perfect.
banjo bolt(a t tap for your fuel line with a fitting for FPG) 5 dollar
mechanical guage(underhood) 50 dollar
summitracing.com
summitracing.com
W O T
Mar 1, 2005 07:10 AM
IN VTEC
Apr 7, 2003 11:40 PM
