My results dyno CTR vs Sk2 over 200hp
Old Oct 7, 2004 | 07:02 AM
sircrxracer's Avatar
Default My results dyno CTR vs Sk2 over 200hp
Just thought I would share my comparison CTR cams VS skunk2 stage 2's
The set-up
97 GSR block with stock bore Pr3 pistons
ITR head shaved .33thou mild port 3 angel valve job
Skunk 2 stage 2 valve springs and retainers
port matched intake mani ITR TB stock
92 lude injectors
D.C ITR JDM 4-1 pretty flat on the bottom
JDM stock air box
Crush bend 2 /14 exhaust 5Zigen can
Tuned with a Fields Vtec controller Vtec liked 5300
On the CTR's I hit 194 with 139 tq after tuned and the Skunk2 stage 2's after 2hrs tunning I hit 204 140tq
I know my exhaust and header are really hurting me my intake box too.
I hope I can dip in the 12's with the street tire pray for me
here's the graphs
CTR vs Skunk2 stage 2's
Skunk2 stage 2's
Any questions or coments are welcome please post here as my IM is fucked up thanks Rob
Old Oct 7, 2004 | 07:08 AM
slow_dx's Avatar
Default Re: My results dyno CTR vs Sk2 over 200hp (sircrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">
Any questions or coments are welcome please post here as my IM is fucked up thanks Rob</TD></TR></TABLE>
Mine looks the same way. I like to make myself feel better about it by pretending that it improves my low end power Would like to cut it out and reweld it at some point.
Nice graphs; I'm especially impressed with the power you were making with the CTR cams -- good power for a factory cam.
Old Oct 7, 2004 | 07:09 AM
RobbieG35's Avatar
12 Years Strong
Those numbers are nutz just to be tuned with a VTEC controller. A good I/H/E and a tune with a standalone would be
Good luck getting in the 12s
Old Oct 7, 2004 | 07:11 AM
Default Re: My results dyno CTR vs Sk2 over 200hp (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">Those numbers are nutz just to be tuned with a VTEC controller. A good I/H/E and a tune with a standalone would be
Good luck getting in the 12s</TD></TR></TABLE>
I think we didn't even touch much with the fields I have the fuel at 70psi though....... it loves the fuel. Rob
Old Oct 7, 2004 | 07:13 AM
RobbieG35's Avatar
12 Years Strong
Did you play with the cam gears at all?
Old Oct 7, 2004 | 07:15 AM
b19coupe's Avatar
Nice #s for a mild build
Old Oct 7, 2004 | 07:17 AM
DefiantGSR's Avatar
Default Re: My results dyno CTR vs Sk2 over 200hp (b19coupe)
wow, didn't think the skunks would beat the CTRs in midrange.
Old Oct 7, 2004 | 07:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">Did you play with the cam gears at all?</TD></TR></TABLE>
Yes we did but my clearences are tight cause of the shaved head someone fucked up but any way I only have 65mm exh and 80mm intake valve to piston so I didn't want to hit anything since I'm 2nd in points series only trailing by 60 pts so I need to win the last event I don't want to hit anything Rob
Old Oct 7, 2004 | 08:12 AM
b19coupe's Avatar
Looks like it's time to update your sig.
Old Oct 7, 2004 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it's time to update your sig.</TD></TR></TABLE>
LOL thanks...... hopefuly after this weeknd I can change the 1/4 and mph Rob
Old Oct 7, 2004 | 09:29 AM
BERT-O's Avatar
thank you for posting your results
Old Oct 7, 2004 | 09:34 AM
BERT-O's Avatar
btw, post up your A/F ratio chart(S)
Old Oct 7, 2004 | 09:36 AM
Default Re: My results dyno CTR vs Sk2 over 200hp (BERT-O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
btw, post up your A/F ratio chart(S)</TD></TR></TABLE>
I don't have any Rob
Old Oct 7, 2004 | 09:45 AM
Sinisterprostok's Avatar
Nice Dyno Chart! You could try getting bigger injectors(310) and turn your fuel pressure down,you should make a little bit more with them.
Old Oct 7, 2004 | 09:52 AM
Default Re: My results dyno CTR vs Sk2 over 200hp (Sinisterprostok)
The 92-96 Lude injectors are over 300cc it just loves the fuel I have a fuel pump too 195lph intank. Rob
Old Oct 7, 2004 | 10:06 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">The 92-96 Lude injectors are over 300cc it just loves the fuel I have a fuel pump too 195lph intank. Rob</TD></TR></TABLE>
92-96 Prelude injectors are 345cc
97+ Prelude are 270cc
One question though; how are you running 70psi! Isn't 60-80psi supposed to damage injectors?
Nice #'s!!!
Old Oct 7, 2004 | 10:21 AM
MaxBoost's Avatar
New User
Default Re: My results dyno CTR vs Sk2 over 200hp (hybrid_vtec)
I had a similar motor and dyno. I broke into the 12's with bfg's and a 1.91 60ft in a 2050lb hatch.
Old Oct 7, 2004 | 10:40 AM
BryanPendleton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">ITR head shaved .33thou mild port 3 angel valve job
Is that .33 of 1/1000th, point .33 inches or is that 33 thousanths of an inch (ie. 033in)? I am assuming 0.033in. Just being an #%@ again.
Old Oct 7, 2004 | 10:45 AM
FerioVtec94's Avatar
Default Re: My results dyno CTR vs Sk2 over 200hp (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">wow, didn't think the skunks would beat the CTRs in midrange. </TD></TR></TABLE>
the skunks didnt beat the ctrs till 6k, but very impressive numbers
you build and numbers was similar to mine with the ctrs (in sig) only i have less compression, i'd be curious to see what mine would do with the skunks
Old Oct 7, 2004 | 11:52 AM
Rollo Lawson's Avatar
very impressive. i wonder what a real intake, 2.5" mandrel exhaust and better header would do, 215whp maybe?
Old Oct 7, 2004 | 12:38 PM
4F_ Mugen CoL's Avatar
thats sick
Old Oct 7, 2004 | 12:57 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (B16C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">very impressive. i wonder what a real intake, 2.5" mandrel exhaust and better header would do, 215whp maybe? </TD></TR></TABLE>
I would put money on it
Old Oct 7, 2004 | 01:04 PM
m00tjam's Avatar
Default Re: (HybridHatch88)
youre my new hero man!
where did you get it tuned?
is that with a pretty much stock ecu (besides the feilds?)
Old Oct 7, 2004 | 02:37 PM
Carlo Gambino's Avatar
sircrxracer ,if you'd like to share, hows the gear setup on that 204hp sk2 stg2 ???
Old Oct 7, 2004 | 02:50 PM
bossman032's Avatar
Default Re: (Carlo Gambino)
ctr cams
this cams do perform very good
