d16a6 missfire
Can't figure out what's causing this missfire at idle. For a short period I had a problem with oil leaking in through the gromets from the valve cover gasket into the cumbustion chamber aroud the spark plugs. i originally thought i could get away with replacing the plugs, wasn't that. Then did the wires the rotor and cap and te ignitor. By now I figure its either the distributor or somethin internally. Has anyone else had this problem that can help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 »</TD></TR><TR><TD CLASS="quote">check cam timing then ignition timing.</TD></TR></TABLE>
dank24
10
Jul 20, 2006 06:29 AM
spcrxracer
17
Apr 7, 2005 01:00 PM
