Has any one seen a standard header that looks like this?????
Old Oct 7, 2004 | 04:12 AM
gavhowe's Avatar
Default Has any one seen a standard header that looks like this?????
This is the standard header that is on my new motor. The car is a UK Civic 5-door VTI-S which comes with a B18C4 and LSD as standard. I am looking to change the header to free a bit of power up.
I want to keep the standard exhaust, because I want to keep the car quite (stealth mode). By changing the header and putting a test pipe in it should still be quite and free up a bit of power.
But I do not know what header to get as no one makes one for it, do you think the JDM Integra R 4-1 will fit it?
Old Oct 7, 2004 | 06:26 AM
b00sted93Hatch's Avatar
Default Re: Has any one seen a standard header that looks like this????? (gavhowe)
Never seen a header like that before. Is it possible that is already a aftermarket header? Take a picture of where the header connects to the cat. SHould be able to tell from there. BTW i wish our us civics came with 1.8 and lsd standards
Old Oct 7, 2004 | 06:53 AM
dip-set's Avatar
Default Re: Has any one seen a standard header that looks like this????? (allMotor93Hatch)
looks like a saab...but i like it,good luck finding a header to fit...
Old Oct 7, 2004 | 06:57 AM
mmuller's Avatar
Mad Scientist
that is a stock header, and yes a jdm integra type r header will fit or any b-series or that matter.
you might have to play with exhaust lenghts a little
Old Oct 7, 2004 | 09:42 AM
91civicDXdude's Avatar
why swap one stock header for another stock header?
I'd keep it if i were you.. looks like its not providing any significant restriction worth paying out the *** for the "JDM TYPE R" overpriced header
EDIT* i just looked at pictures i have of another VTi with the same B18C4 and it also has that exact same header, so im assuming that yes,it is stock
Old Oct 7, 2004 | 10:18 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
That looks like a really nice stock piece. I don't think you could free up much if any power by going with something else. Good luck though.
Old Oct 7, 2004 | 11:12 AM
EK22snatch
Guest
Posts: n/a
Default Re: Has any one seen a standard header that looks like this????? (tjbizzo)
i dont know the answer to your question, but i just gotta say your car looks pretty nice man. me likey!
Old Oct 7, 2004 | 11:41 AM
urosch's Avatar
Default Re: Has any one seen a standard header that looks like this????? (EK22snatch)
Just buy ITR transmision or ITR final drive. Your stealth mode would be much better!
Old Oct 8, 2004 | 07:00 AM
gavhowe's Avatar
Default Re: Has any one seen a standard header that looks like this????? (urosch)
is the final drive different on the itr then? What is the gear box number for one of those transmissions??
Old Oct 8, 2004 | 07:26 AM
gavhowe's Avatar
Where is the transmission number on my car? is it S9B 100330 E5 LSD does that look right or is that the another number and not the gear box number.
Old Oct 8, 2004 | 07:34 AM
urosch's Avatar
Friend have 1.8 VTI only red one. You have to change final drive and 1st gear bearing and something else for first gear(usualy you get it in kit when you buy ITR final drive) and I don`t know to write this thing in english.
Old Oct 8, 2004 | 07:38 AM
urosch's Avatar
S9B is the number.
Old Oct 8, 2004 | 08:48 AM
sprayedcrx's Avatar
bad *** car first ive seen good luck with the header
Old Oct 11, 2004 | 09:27 PM
sprayedcrx's Avatar
bump
amimaxima
Jan 26, 2009 03:56 AM
RedneckRicer
Apr 3, 2008 12:05 PM
PPLH8R
Welding / Fabrication
14
Jan 20, 2008 11:58 AM
hybridpatient95
14
May 1, 2005 02:52 PM
