Power of a fully built K20A Type-R
Old Oct 7, 2004 | 01:20 AM
K20egcivic's Avatar
Default Power of a fully built K20A Type-R
I am buying a K20A Type-R, and I want to know if its worth it to put in a Toda stroker kit, high power connecting rods, high compression pistions, High power head gasket, ITBs,port and polish head, valve train work, camshafts, cam gears, and almost everything is from toda racing. How much power could I make???? Please reply A.S.A.P
Old Oct 7, 2004 | 03:07 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Power of a fully built K20A Type-R (K20egcivic)
I think that would be a big waste of money. I am a big Toda fan, but some of their products are REALLY overpriced and there are some other products better than what Toda offers. There are too many variables to determine how much power you can make. Its all about tuning
Old Oct 7, 2004 | 04:03 AM
Twin-cam's Avatar
Stoker kit for K series? from toda? i dont believe it.
Buy the toda camshaft kit, and with open intake & good exhaust it makes 260HP+
Old Oct 7, 2004 | 05:35 AM
98itr0448's Avatar
Dart sleeves are in testing phase....hmmm.
Old Oct 7, 2004 | 05:38 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20egcivic &raquo;</TD></TR><TR><TD CLASS="quote">I am buying a K20A Type-R, and I want to know if its worth it to put in a Toda....</TD></TR></TABLE>
Tell us what you're doing w/the motor, and that'll help people help you.
Old Oct 7, 2004 | 08:13 AM
CRX_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20egcivic &raquo;</TD></TR><TR><TD CLASS="quote">I am buying a K20A Type-R, and I want to know if its worth it to put in a Toda stroker kit, high power connecting rods, high compression pistions, High power head gasket, ITBs,port and polish head, valve train work, camshafts, cam gears, and almost everything is from toda racing. How much power could I make???? Please reply A.S.A.P</TD></TR></TABLE>
I could sell all my organs and still not not have enough to afford what you just listed.
Old Oct 7, 2004 | 09:42 AM
Hondog's Avatar
Default Re: Power of a fully built K20A Type-R (CRX_VTEC)
I dont beleive it is worthwhile doing it all yet.. Personally I'd do the transplant run it stock and then build it in a years time when alot more performance products have hit the market... From the K20A-R you can run 200+WHp depending on the dyno with a simple I/H/E and a management system..
Old Oct 7, 2004 | 10:25 AM
MaxBoost's Avatar
New User
Default Re: Power of a fully built K20A Type-R (Hondog)
Screw all the Toda ****...
Get your compression up with some pistons, im sure the stock rods are fine, but if anything get some really light aftermarket units. HyTech makes 4 different cam profiles, plus valvesprings and retainers. Im sure RLZ or Portflow can port the manifold and head, big tb, hondata kpro, fuel system, hytech/dtr/etc header..yur done..
Old Oct 7, 2004 | 10:36 AM
dsisive407's Avatar
From: around the corner to the left ... no, your other left
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
I could sell all my organs and still not not have enough to afford what you just listed. </TD></TR></TABLE>
lmfao .. thats about right.
Old Oct 7, 2004 | 11:09 AM
FF lotus's Avatar
way more than any street tire can handle, and probably more than your car could ever use
aka pointless
Old Oct 7, 2004 | 11:22 AM
Alberto's Avatar
Search. I have a list of many parts already available for the K-series and only two of those parts are from Toda.
Old Oct 7, 2004 | 07:21 PM
AussieK24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondog &raquo;</TD></TR><TR><TD CLASS="quote">I dont beleive it is worthwhile doing it all yet.. Personally I'd do the transplant run it stock and then build it in a years time when alot more performance products have hit the market... From the K20A-R you can run 200+WHp depending on the dyno with a simple I/H/E and a management system..</TD></TR></TABLE>
I'd worry about getting the car up and running first with a mild K motor
megamanx057
Jan 3, 2013 08:58 PM
TsukubaSpec
Mar 24, 2004 10:43 PM
bitr364
Mar 9, 2003 12:54 AM
JDMchris
May 28, 2002 09:55 PM
H23 Power
Aug 17, 2001 11:41 AM
