tig welding 4130 cages
hey guys had a ? on welding roll cages well tig welding them.im just geting into building cages and trying to figure out the best way to them.and as clean of weld as possible.
ive heard of people fabing the cage out of the car and cutting the roof of this sounds like a very clean way of doing it.but is it worth the time.im 30 years old and my knees arnt what they used to be.have you guys ever used a torch mounted remote for this.or do you use foot pedal in crazy positions.you guys know what im talking about.is the torch mounted remote worth the money.
Hi, a torch mounted remote is the only way to go when ur welding out of position. I recently just built a cage for 89 honda crx that I made in to a circle track car. I cut the top and welded it out of the car after I cut, bent, fitted, and tacked it together in the car. The trick to tig a cage is your joints have to have little to no gap. Welding a cage in the car is a pain I had to add a couple of thing to mine after I had already mounted. Have fun with it and any ?'s just ask I'll try to answer them as best as possible. O yea I would use a torch mount remote if its possible.
You will have to use a torch mounted remote cause it is a pain in the *** trying to work the pedal in the positions you will be in.
When i'm in a tough position, i put the welder on "lift arc" and a constant amperage so you touch the metal to start the arc and then it's on at a constant. You have to make sure you don't set the amperage too high cause it's full on when you do it, but if you set it up right it works great. You can get in some crazy positions when you don't have to worry about the pedal!! lol
i use any part of my body to control the pedal at times... shoulder, head, knee... whatever it takes... iv even called over a friend and just told them "push the pedal"... "ok... let go of it." lol
the worst thing imo is looking at a spot u have to weld only to find out ur head doesnt fit with the helmet on very well...
and like bakyard said... try to have little to no gap... it makes life SO much easier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t »</TD></TR><TR><TD CLASS="quote">the worst thing imo is looking at a spot u have to weld only to find out ur head doesnt fit with the helmet on very well...
Nothing worng with taping the lense to your head. Jsut make sure you shaved that day.
Yes It's a pain in the ***. You'll have to use the pedal with all parts of your body.
i found putting the pedal in between my legs and squeeze works very well.
also you'll need to play around with different cups and torch ends so you can mover around freely.
Having a welding with pulse also works very well too.
RACEPAK
Nov 17, 2012 07:42 PM
PSIBuildersBiomb
Welding / Fabrication
Dec 22, 2008 09:17 AM
JG-Fabrications
30
Jan 15, 2008 03:51 PM
