Spark plugs and JDM vs. USDM ITR motor
Old Oct 6, 2004 | 11:54 PM
NXSpoon's Avatar
Default Spark plugs and JDM vs. USDM ITR motor
Searching revealed 2 slightly different part numbers for both OEM versions of the ITR engine:
NGK-R PFR7G-11 for the JDM B18C-R
and
NGK PFR6G-11 for the USDM version.
Why the difference, compression?? Will it matter any if I use the OEM USDM plugs in aJDM ITR motor??
Old Oct 7, 2004 | 12:00 AM
b19coupe's Avatar
Default Re: Spark plugs and JDM vs. USDM ITR motor (NXSpoon)
JDM = higher compression and higher combustion chamber temps. Thus the colder plug (7). A PFR6G-11 will be o.k., but you can pick up the PFR7G-11's at your local Acura dealer if you like. It's an optional plug for the 92-95 Legends. Or you can find them at a few places online:
http://clubplug.net/retail_laser_ngk.html
For one.
Old Oct 7, 2004 | 12:03 AM
Boges's Avatar
The only difference between those two I think would be the heat range. The numbers 6 and 7 represent the heat range for these NGK spark plugs.
If it helps, I've used the PFR6G-11 in a JDM ITR enging without any issues.
Old Oct 7, 2004 | 12:09 AM
NXSpoon's Avatar
Default Re: Spark plugs and JDM vs. USDM ITR motor (Boges)
Thanks guys
Old Oct 7, 2004 | 12:22 AM
voofee's Avatar
If you want the iridium alternative, the ifr7g-11 found in rsx-s is good too
DC2-ProdUcTiOnS
Sep 22, 2023 03:59 AM
my crx
Nov 23, 2015 09:38 AM
NinjaJDMB18c
Oct 21, 2013 08:18 AM
twentyhurtz
Feb 19, 2009 05:29 AM
lv6l
11
Apr 21, 2006 11:42 AM
