how tuff is it do OBD2-OBD1 conversion by myself
Old Oct 6, 2004 | 11:02 PM
yeegsr's Avatar
Default how tuff is it do OBD2-OBD1 conversion by myself
i know i will need OBD1 ECU, OBD1 converstin, +wire harness, as well as jumpers
how complicate is this...i wanna do it myself but should i try or wat....i kindda want to know more about my car..instead of having someone else doing it....
anyone have some suggestion to this
Old Oct 6, 2004 | 11:05 PM
allmotorej8's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (yeegsr)
all u need the the obd-2a/b to obd-1 harness and the obd-1 ecu to convert to obd-1
Old Oct 7, 2004 | 04:18 AM
Blown90hatcH's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (aLLmTreK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aLLmTreK &raquo;</TD></TR><TR><TD CLASS="quote">all u need the the obd-2a/b to obd-1 harness and the obd-1 ecu to convert to obd-1</TD></TR></TABLE>
Yup. 10 mins.
Old Oct 7, 2004 | 08:09 PM
yeegsr's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Yup. 10 mins.</TD></TR></TABLE>
hopefully you dont over exaggerated the timing....man i was thinking the average time needed is about 2hrs or more
is it easy though...i mean electronically
Old Oct 8, 2004 | 02:55 AM
GOLDBERG's Avatar
plug n play, hehe...
Old Oct 8, 2004 | 03:14 AM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
is it easy though...i mean electronically</TD></TR></TABLE>
There's nothing to do electronically. You unplug your old ECU, plug the conversion harness into the car's harness, and plug the OBD-1 ECU into the harness.
Old Oct 8, 2004 | 03:53 AM
civic-4-ges's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (GeeReg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeReg &raquo;</TD></TR><TR><TD CLASS="quote">
There's nothing to do electronically. You unplug your old ECU, plug the conversion harness into the car's harness, and plug the OBD-1 ECU into the harness. </TD></TR></TABLE>
If that takes more than 10 minutes, you got problems!!!
Don't even need to disconnect your negative battery terminal, but its not a bad idea!
Old Oct 8, 2004 | 05:28 AM
hype r 555's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">
Don't even need to disconnect your negative battery terminal, but its not a bad idea!</TD></TR></TABLE>
it really is that easy - 6 plugs - 4 screws - 1 kick panel cover .... smile from ear to ear
Old Jan 7, 2005 | 01:02 PM
BlueShadow's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (lsed-eg)
Hey guys I just wanted to bring this thread back from the dead.
This is not really for me, it's for one of my friends. For the OBD 2 to OBD 1 conversion, you guys say that all that is needed is the OBD 2 to OBD 1 conversion harness and the OBD 1 ECU? you dont need to change out our OBD 2 dizzy to OBD 1 or anything else?
A friend of mine has a 96+ Teg LS with a turbo and I might try to convince him to swap to OBD 1 so he can run uberdata.
TIA
Old Jan 7, 2005 | 01:34 PM
Mr_CRX's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (BlueShadow)
OBD 1/2 distributors are the same thing, just the plug is different.
I'm running an OBD2 distributor on my obd1 setup.
Old Jan 7, 2005 | 01:35 PM
GOLDBERG's Avatar
mope leave your obd2 dizzy
Old Jan 7, 2005 | 01:46 PM
BlueShadow's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (GOLDBERG)
cool, thanks for letting me know guys...I just wanted to check and make sure. This dude I know from work is running a DRAG kit with the RRFPR. Since I will soon have all the uberdata software, I might be able to help him out by getting him to switch to OBD 1 and burn his ECU's for him.
Thanks again guys
Old Mar 28, 2005 | 07:48 PM
elpiar's Avatar
I have obd2b P72 from my 2000 GSR, swapping to P72 OBD1. Some people say I need to do something for the knock sensor to work, in addition to the harness and ECU swap.
Is this true?
Old Mar 29, 2005 | 06:09 AM
EM1SiR's Avatar
Default Re: how tuff is it do OBD2-OBD1 conversion by myself (elpiar)
Plug and play. it doesn't take very long to do the conversion. no more than 10 min. it took me 9 min
Old Mar 30, 2005 | 10:49 AM
CivicMike's Avatar
gonna do this tonite, should I expect the CEL after i swap ecus or what? 97 EX coupe converting to OBD1 p28 ECU for uberdata and TURBO
Old Apr 3, 2006 | 06:36 PM
wrEcKed_LX's Avatar
Default Re: (CivicMike)
kinda bringing a thread bakc from the dead, but do you need to change the iac valve to a two wire or something?
pdiggitydogg
Jul 12, 2007 01:05 PM
integra racr04
May 13, 2007 08:56 PM
Hazymix
Oct 28, 2006 06:41 AM
mrx
Feb 25, 2005 12:36 AM
gsrhatch530
Sep 21, 2002 03:11 PM
