92 Civic HB Si ready to swap!
My 92 Civic HB Si ready to swap! I want to do a Sir1 swap since it is more affordable. But since Sir1 use cable for tranny and my 92 EG5 use hydrualic. May I know what should I be aware of? Thanks
just buy a hydro gs-r or b16 tranny. you'll need mounts, distributer from a 94-95 DOHC vtec, injectors from a 92-95 integ, and you'll need a P30, P72 or a dohc spec p28 ecu.
you can actually use your ex injectors, you can also use your current driver side mount and you should be able to use the rest of that mounts from the 1st gen, i could be wrong that the rear mount wont work though.
crxswap
Dec 28, 2009 12:12 PM
sosleepy
Jul 23, 2005 02:47 PM
boss0025
Jul 31, 2004 10:30 AM
