HELP!!!!!
i just did the mpfi swap on my 89 crx dx. when i try to start the car, gas sprays out from the injectors! i'm hoping its just the o-rings on the injectors but it coming from the top where the injectors meet the fuel rail...any help would be appreciated!!!
The wiring wouldn't cause fuel to spray out like you are describing. Replacing the orings would be a good place to start but what are the chances that all the orings are bad unless they are really old.
If you have the problem after replacing the orings you may want to borrow a fuel rail and try that out with your injectors. Lets us know what happens. Later
check the o rings, then make sure your fuel rail is tightened down very well. those nuts have to be very tight, but careful cause i broke one of the studs when i had the same problem.
littleprophet13
Feb 15, 2010 07:47 PM
