speedometer making weird noise?
Old Oct 6, 2004 | 09:37 PM
ACRProject's Avatar
Default speedometer making weird noise?
Well I replaced my speedo cable sometime in May, but recently I been hearing a weird noise like something is loose or needs some lube in my gauge cluster. It only occurs during acceleration above 40 mph and eventually stops when the gas is steady. If anyone had this problem before please inform me what you did to stop this or if you have any tips how i can fix this i will be very grateful.
I already tried to lube up where the cable goes into the cluster, but didn't help at all...I think its something inside the gauge cluster.
Old Oct 6, 2004 | 09:51 PM
EVOLUTIONINNYC's Avatar
maybe its just something rattling in your cluster?
Old Oct 6, 2004 | 10:21 PM
ef9wpb's Avatar
Default Re: (SiRhatchalot)
thats funny i thaught i was the only one...
i dont know if it still does it, but im gonna make note next time i drive.
Old Oct 6, 2004 | 11:12 PM
RedRacerCivic's Avatar
Default Re: (ef9wpb)
just don't do anything, it will eventually go away. Mine did the same exact thing, i just ignored it, now its gone lol.
p.s. don't take my advice if you are not lazy
Old Oct 7, 2004 | 02:09 AM
5litereater's Avatar
Default Re: (RedRacerCivic)
i just got my car back together and my speedo/gauge cluster makes a noise now (havnt noticed it till now cuz i had no speedo). i have no idea where its coming from nor how to fix it.
Old Oct 8, 2004 | 03:35 AM
ACRProject's Avatar
Default Re: speedometer making weird noise? (ACRProject)
I will hopefully take my cluster apart tomorrow...If I fix the problem I will let you guys know how I fixed it.
Old Oct 14, 2004 | 03:01 PM
PreStaged12s's Avatar
You cant fix anything! HA HA. Last time you fixed something nobody ever saw it again!
Old Oct 14, 2004 | 10:12 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRacerCivic &raquo;</TD></TR><TR><TD CLASS="quote">just don't do anything, it will eventually go away. Mine did the same exact thing, i just ignored it, now its gone lol.</TD></TR></TABLE>
i second that.
Old Oct 15, 2004 | 12:21 PM
ACRProject's Avatar
Default Re: speedometer making weird noise? (PreStaged12s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s &raquo;</TD></TR><TR><TD CLASS="quote">You cant fix anything! HA HA. Last time you fixed something nobody ever saw it again!</TD></TR></TABLE>
Not a lot of people seemed to have this problem and I was too lazy to post again .
Anyways, the gauge cluster isn't the source of the problem. I decided to drive around without the gauge cluster and I pin pointed that the speedo cable itself is making the weird noise. The first thing I decided to do was to remove the inner cable. I took some high temp bearing grease and lubed it. Reinstalled the inner cable and took the car out for a spin w/o the gauge cluster on. This cured the problem for about a week.
The noise came back but isn't as noticeable as it used to be. I believe that the position of the cable could be a problem. The speedo cable mounted in the factory locations has a S shape bend to it. I will try to reposition the cable again and see if this will solve the problem permanently.
If you don't see a response in awhile you know why.
Old Oct 15, 2004 | 12:34 PM
Home Skillet's Avatar
Yeah, my crap does that too around 90MPH . It's quite annoying, I'll try moving the inner cable around.
Old Oct 15, 2004 | 12:44 PM
Maybe we can fix it later, what kinda grease did you use? Maybe take the CRX race car cluster if its bothering you.
Old Oct 15, 2004 | 01:09 PM
ACRProject's Avatar
The grease I am using is Mag1 Hi-Temp Disc Brake Wheel Bearing Grease
Old Oct 15, 2004 | 01:57 PM
Get some of the Red Line assembly lube, just use a little bit.
meyerk9
Dec 19, 2010 11:27 AM
iheartmyej8
Nov 24, 2008 05:55 AM
90ZCREX
Feb 16, 2005 01:35 PM
92integraVTECgsr
Dec 22, 2004 04:25 PM
