Ex exhaust manifold for ZC? questions.
Old Oct 6, 2004 | 06:43 PM
vmm's Avatar
vmm
Default Ex exhaust manifold for ZC? questions.
on the Zcr.com, it says to swap the exhaust manifold of an Ex because it bigger. but the thing is i dont know wat year an Ex civic is from. its on this site. http://www.thezcr.com/modules....cat=5
if this is true then im hit up a junkyard and get one
Old Oct 6, 2004 | 06:53 PM
dr_latino999's Avatar
Default Re: Ex exhaust manifold for ZC? questions. (vmm)
I believe it is the EX manifolds off the 96-00, or maybe more specific to 98-00.
Old Oct 6, 2004 | 11:47 PM
Nerologic's Avatar
i would go with a ZC upper, and the lower off of a 92+ sohc vtec motor (y8 0r z6)
the upper portion of the ZC is actually bigger (runner wise) then the sohc's but the lower section is better on the sohc's so a combo of both is best
Old Oct 8, 2004 | 09:06 AM
vmm's Avatar
vmm
Default Re: (Nerologic)
im kinda a newbie still.. so u mean, keep the zc upper manifold, but change the header manifold to a one off of a 92 + sohc vtec motor rite?
Old Oct 8, 2004 | 09:54 AM
Nerologic's Avatar
right keep the sohc downpipe, because it flows better then the ZC one...and keep the upper ZC portion. Also only thing about this setup, it will kinda hang slightly...
Old Oct 10, 2004 | 06:50 PM
vmm's Avatar
vmm
will i even notice ne gains?
Old Oct 10, 2004 | 07:46 PM
4potnick's Avatar
Default Re: (vmm)
I used sohc header from 2000 ex. ports lined up almost perfect.
Modified by 4potnick at 5:06 AM 10/11/2004
Old Oct 10, 2004 | 08:05 PM
Nerologic's Avatar
Default Re: (4potnick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vmm &raquo;</TD></TR><TR><TD CLASS="quote">will i even notice ne gains?</TD></TR></TABLE>
if your motor is stock, prolly not....
IP RACING
Dec 28, 2006 08:58 PM
h22_crx
Aug 23, 2005 09:46 PM
hondacivic4g
May 12, 2005 10:56 PM
1badrex
Dec 26, 2003 04:48 AM
chron1k
Oct 19, 2002 11:31 AM
