is this bad on my timing? (dohc zc)
Old Oct 6, 2004 | 06:29 PM
hatchinprogress's Avatar
Default is this bad on my timing? (dohc zc)
my problem is that i have a dohc zc and i was lookin at the cam gears and i noticed by the marks (on gears) that it looks like the exhaust gear and the intake gear's are a little off. now my car hasnt been runnin strange or anything but the gears were line up before. so what could cause this?? and how bad is it on the timing?? the idle has all ways been "strange" (kinda high) i was told as long as its not runnin rough, but im also wondering if this could be apart of my bad idle?? any ideas???
Old Oct 6, 2004 | 06:39 PM
Maddox's Avatar
Default Re: is this bad on my timing? (hatchinprogress)
You think your cam gears are a tooth off?
Old Oct 6, 2004 | 06:41 PM
Default Re: is this bad on my timing? (AllMotorCRX161)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorCRX161 &raquo;</TD></TR><TR><TD CLASS="quote">You think your cam gears are a tooth off?
</TD></TR></TABLE> yeah about 1 mayybee 2? is that real bad?
Old Oct 6, 2004 | 06:43 PM
Sho Pow's Avatar
Both lines dont match up perfect when setting timing. If you take off the valve cover you will see 2 holes where you can put an allen key or a punch through the head into the cams.
Old Oct 6, 2004 | 06:47 PM
Default Re: (Sho Pow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sho Pow &raquo;</TD></TR><TR><TD CLASS="quote">Both lines dont match up perfect when setting timing. If you take off the valve cover you will see 2 holes where you can put an allen key or a punch through the head into the cams. </TD></TR></TABLE> and what does that mean?? sorry i dont understand is that a way to fix it? because i plan on doin my valves soon
Old Oct 6, 2004 | 06:56 PM
Maddox's Avatar
Default Re: (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> and what does that mean?? sorry i dont understand is that a way to fix it? because i plan on doin my valves soon</TD></TR></TABLE>
You can see if your timming is dead on or not. If they line up then you dont have a problem, but if you can only get one in then your off a tooth.
Old Oct 6, 2004 | 07:03 PM
Default Re: (AllMotorCRX161)
and how bad is it if im only off a tooth?
Old Oct 6, 2004 | 07:09 PM
Maddox's Avatar
You want to be dead on..You dont want to be off in your timming.... and if you said that it was perfect and now its not that means that the belt is slipping which is very bad... If I see you some time this weekend I will check it out for you if you want
Old Oct 6, 2004 | 07:12 PM
yeah that would be cool, cuz im not that comfortable with doin timing when the swap was done my homie did the timing stuff
brownsEF
Mar 27, 2009 06:21 AM
VegaS10
Dec 26, 2005 01:36 PM
qwksi1
Mar 24, 2004 11:27 AM
efjuice
Oct 14, 2003 09:36 AM
seeweed
Feb 12, 2002 09:05 PM
