ls crank gsr block girdle?
Old Oct 6, 2004 | 05:19 PM
ferio 95's Avatar
Default ls crank gsr block girdle?
Im in the process of slapping my ls crank in my gsr and the thought popped in my head. can i use my gsr oil pickup and block girdle on the ls crank and rods? and which main bolts do i use?
Old Oct 6, 2004 | 09:53 PM
ferio 95's Avatar
Default Re: ls crank gsr block girdle? (ferio 95)
bump
Old Oct 6, 2004 | 10:41 PM
thad
Guest
Posts: n/a
ya gotta do some modification to the caps to make it fit, you'll use the gsr bolts.
Old Oct 6, 2004 | 10:44 PM
ferio 95's Avatar
Default Re: ls crank gsr block girdle? (thad)
got any pics or can you explain better the cap mod? and can anyone confirm this?
Old Oct 7, 2004 | 05:46 AM
b19coupe's Avatar
I am using a 92mm stroker crank and no modification to the main caps, windage tray, or oil pick up were necessary.
Old Oct 7, 2004 | 06:07 AM
StyleTEG's Avatar
Default Re: ls crank gsr block girdle? (b19coupe)
You have to have the main caps align honed to the girdle if you are running a block that previously didn't have a girdle.
If you already had the girdle and are just using an LS crank, then no you probably don't have to do any modifications. (I don't think there are any clearance issues).
Old Oct 7, 2004 | 08:58 AM
ferio 95's Avatar
Default Re: ls crank gsr block girdle? (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">If you already had the girdle and are just using an LS crank, then no you probably don't have to do any modifications. (I don't think there are any clearance issues).</TD></TR></TABLE> yea thats what im doing. i dont see where there would be any issues but i wanted a 2nd or 3rd opinion
03EM2guy
19
Mar 28, 2011 06:00 AM
EH3forlife
19
Oct 23, 2007 07:02 PM
aser1z
Jul 28, 2005 06:47 PM
blu3g
Jul 14, 2005 09:52 PM
black-hatch
Mar 13, 2003 08:54 PM
