Wire gauge and amp power
Old Oct 6, 2004 | 05:14 PM
Gman8941's Avatar
Default Wire gauge and amp power
My friend an I have been fighting over a simple easy thing. Is 8 gauge wire signifigant for a MTX 500x1 or is it gonna starv it. so lets settle this. What wire would you use to wire your 500watt CEA compliant amp.
Old Oct 6, 2004 | 06:20 PM
civic_speed99's Avatar
I've got 8 guage running my 600W amp and it sounds good and I have never had any problems. But just incase you upgrade in the future, go with the 4 Guage...
Old Oct 6, 2004 | 07:34 PM
kontai69's Avatar
Default Re: Wire gauge calculator
Use the wire calculator on this page to determine exactly what gauge wire you will need for a given amp power rating...
http://www.bcae1.com/wire.htm
You also have to factor in the length of the wire.
Old Oct 6, 2004 | 09:31 PM
b18bEG's Avatar
0GA for everything
Old Oct 7, 2004 | 07:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: Wire gauge calculator (kontai69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kontai69 &raquo;</TD></TR><TR><TD CLASS="quote">Use the wire calculator on this page to determine exactly what gauge wire you will need for a given amp power rating...
</TD></TR></TABLE>Dito all that 94
Old Oct 7, 2004 | 07:01 PM
foz's Avatar
foz
Default Re: Wire gauge and amp power (Gman8941)
for the price diference, it's worth it to do a little overkill, why starve the amp if it wants the power, I'd run 4ga for a single amp, it if was a small high's amp I might only run 8ga, but for most any sub amp I'd run a minimum of 4ga, it'll never hurt to go oversize...ask your girl she'll tell ya bigger is better
Old Oct 8, 2004 | 08:34 AM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: Wire gauge and amp power (foz)
depends on how the amp acts... if it gets really hot, or clips (cuts in and out) it means that it needs more power...
Old Oct 8, 2004 | 08:35 AM
Odessa's Avatar
4ga or bigger. Think what you gonna do when you decide to upgrade? Redo the cable again??
Old Oct 9, 2004 | 10:49 AM
Spider Man's Avatar
Default Re: Wire gauge and amp power (Odessa)
4awg, but if the amp can't even take a 4awg bare wire, useless.
If the amp takes a 8 awg bare, tehn all u need is an 8awg main wire.
Old Oct 9, 2004 | 11:55 AM
archmage's Avatar
8 Gauge is probably enough for the amp alone. I run 8 gauge to my amps, the most powerful of which is 120x4@ 4 ohms (pretty big amp, although I don't use all that power).
If I were to wire a car though, I'd simply go 4 gauge and run through a simple distribution block - run the 8gauge out of that to the amp. This leaves room for upgrade, and it isn't overdoing it.
There is no reason to go over about 4 gauge unless you are redoing the electrical system (at least on our puny Hondas).
There ya go.
Old Oct 9, 2004 | 06:37 PM
SiR Inspired ED7's Avatar
i voted for 4gauge, if ur an idiot use small lil wires, let the wire melt
Old Oct 10, 2004 | 08:13 AM
EBP_SI's Avatar
Default Re: Wire gauge and amp power (-=*Dusk2Dawn*=-)
what is the amp fused for? that should be a good indication of what size wire to use. doesnt the manual tell you which size wire is the minimum?
CHAMPwhteEK
Audio / Security / Video
Jan 18, 2009 12:55 PM
imadigitalgod
Jan 5, 2009 08:13 AM
MilanoCivic97
Apr 4, 2007 11:22 AM
hybrid1990crx
14
Jul 14, 2006 06:46 AM
