alternator question
Old Oct 6, 2004 | 05:04 PM
zCivic's Avatar
Default alternator question
I have a 89 crx using a 89 teg ls ECU both of which are OBD0.
I'm using a 92-95 OBD1 civic alt, for some reason I have a misterious CEL
no LED flashes. When I start up and sits, no CEL but once start driving the CEL appears. Is the problem the alt plug, could one of the 4 wires be in a different location. Will a pin swap fix it and if so which ones need to be moved. Will either have to get a pin swap or change alt pullies and put it on a 88-91 alt. I'm using a 92-95 D15B7.
Modified by zCivic at 9:17 PM 10/6/2004
Old Oct 6, 2004 | 05:11 PM
RCautoworks's Avatar
Default Re: alternator question (zCivic)
What code is it throwin ?
Old Oct 6, 2004 | 05:16 PM
zCivic's Avatar
Default Re: alternator question (90blackcrx)
no code at all...thats the first thing I checked....No LED flashed on ECU...just to test the LED I unplugged the C plug car died of course but it did flash so the LED works
Old Oct 7, 2004 | 12:08 AM
Nerologic's Avatar
its not the alt, i have been running 92+ alt's on obd0 cars for years now, not a problem (except for obd2's diff plug) but yeah, its something else...
Old Oct 8, 2004 | 04:00 PM
zCivic's Avatar
I'm so happy...finally threw the code I was thinking it was code 20 ELD....now to find the problem...
JDMeg98382
Jun 28, 2008 12:30 PM
daklown
14
May 23, 2007 10:13 PM
boosted k20
Jul 27, 2005 07:14 AM
wu tang
Apr 5, 2003 07:00 PM
