Im stuck and dont know what to do
Old Oct 6, 2004 | 04:06 PM
bigblueandyellow's Avatar
Default Im stuck and dont know what to do
I have a d16z6 & tranny for $400 (canadian) for my ef hatch, from a friends motor, all it needs is a couple seals and its ready to go, only problem is that the valve cover front mid bolt does not tighten all the way, it is stripped :S..... I dont want to re-tap it because i dont want to have to clean out the head of the motor...hoping there is another way around it. Also where can i pick up the transmission housing bolts, it didnt come with any
Thanks if you can help out guys!!!
Old Oct 6, 2004 | 04:12 PM
mugenracer's Avatar
you dont need to re-tap for those bolts, remove the valve cover and screw out the bolt and replace it with a new one. Then put teh valve cover back on and replace the top nut....you may also need a new nut but its a 10mm nut and so easily available.
DC206R
Feb 23, 2009 09:38 AM
SOHC_MShue
95
Dec 20, 2008 04:00 PM
Jdmglenn
May 5, 2005 09:40 AM
rayscar
Oct 11, 2004 10:34 AM
bartek_b
Apr 15, 2003 11:21 AM
