fitting right next to oil filter, what is it and how do I unplug it?
Is it the knock sensor? I'm trying to disassemble the engine enough to put into bins until I can swap next spring
On the left of the filter . . . . plastic plug is the knock sensor . . . one below it and a bit to the left is and has a rubber cover shaped like a kisses chocolate is the for the oil sensor. . . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs »</TD></TR><TR><TD CLASS="quote">On the left of the filter . . . . plastic plug is the knock sensor . . . one below it and a bit to the left is and has a rubber cover shaped like a kisses chocolate is the for the oil sensor. . . . .</TD></TR></TABLE>
The oil pressure sensor plug is just above the oil filter on a y7.
