Which ARP Head Studs for ls/vtec?
Old Oct 6, 2004 | 11:29 AM
Vtak's Avatar
Default Which ARP Head Studs for ls/vtec?
Curious if anyone knows FOR SURE which ARP Head Studs i should order for my ls/vtec? Its a b18a1 block with a b17 head. Any info greatly appreciated. TIA
Old Oct 6, 2004 | 12:43 PM
Newman's Avatar
New User
Default Re: Which ARP Head Studs for ls/vtec? (ls_vtec_gs-r)
Get GSR head studs. They're longer than B16 head studs.
Old Oct 6, 2004 | 04:08 PM
Turbocivic94's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (Newman)
what he said
Old Oct 6, 2004 | 06:57 PM
The Destroyer's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (Turbocivic94)
GSR, mmm hmmm.
Hey Newman, when are you gonna get some of those airboxes again? (Mugen Replica's)
Check out the AEBS Studs too, they are both good studs.
Old Oct 7, 2004 | 03:03 AM
Vtak's Avatar
sweet....appreciate it guys. I heard good things about AEBS studs too but i have to go with ARP just simply because of their history and track record.
Old Nov 4, 2004 | 06:09 AM
scoop's Avatar
yep definitely GSR head studs
Old Nov 4, 2004 | 07:47 AM
98itr0448's Avatar
The Gsr studs as mentioned. I ordered some from a company and they sent me the ls one's. I had to buy another set from someone else, b/c they were wanting to charge me 157.00 for the replacement set! ******** at Dynoflo Performance, oh and they are on ebay. Good prices, but a definate lack of product knowledge and customer service)
Old Jan 20, 2005 | 07:21 PM
eg6T's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (LSVtecITR)
still use gsr arp studs for a ls block and a b16 head?thanks
Old Jan 28, 2005 | 12:00 PM
R THIS's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (eg6T)
im wondering the same thing.. ls vtec with a ls block and b16 head
are b16 head studs long enough?? or do i have to get GSR studs??
Old Jan 28, 2005 | 12:27 PM
ek2k's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (R THIS)
yeah i want to know the same thing i have a b20b block and b16 head? what arp bolt gsr's? or b16?
Old Jan 28, 2005 | 05:21 PM
eg6T's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (ek2k)
i think i read to use the gsr's,i hope
Old Jan 29, 2005 | 11:47 AM
eg6T's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (suprfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suprfast &raquo;</TD></TR><TR><TD CLASS="quote">last time i checked ARP actually makes an LSVTEC/B20VTEC head stud combo. let me find it. damn, i wish we could just upload pictures.
well anyways. the part number is 208-4306
kris</TD></TR></TABLE>
thanks man
Old Feb 1, 2005 | 02:19 PM
non-VTEC's Avatar
i just finished bolting up my B16 head to a B20 block with ARP studs for a GSR engine.......worked fine.........those are the correct ARP studs you need
Old Feb 1, 2005 | 03:23 PM
MenaceL.A.671's Avatar
GSR ones... thats what i have... on.. and dont for get the connecting rod bolts too.. revvin time..
Old Feb 1, 2005 | 04:07 PM
Blue Hybrid's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (m2slsvtec)
yes exactly what this guy said i have gsr on mines, gsr head studs for lsvtec with b16 head, dont forget rod bolts 8mm, not 9, 9 will not work
Old Feb 2, 2005 | 06:57 AM
lightning's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (gold EF)
Use the GSR, they are 150-thousandths longer than the B16. The 208-4303 is exactly equal to the 208-4306, same studs, same nuts, and same washers. ARP didn't fiure it out until they had created another part number.
Tom
Old Feb 2, 2005 | 10:25 AM
ek2k's Avatar
Default Re: Which ARP Head Studs for ls/vtec? (lightning)
i am going to order arp rod bolts for my b20 vtec with a b16 head but for sure is it 8mm rod bolts or is it 9mm? because isnt a b20 2.0l so wouldnt 9's be the best can someone help?
Old Feb 2, 2005 | 01:30 PM
its 8mm for sure because the 9mm's only fit on the gsr rods. the hole size on the rod is different, so you cannot use the 9mm's on a B20, 8mm for sure : )
Old Feb 2, 2005 | 02:17 PM
ek2k's Avatar
thanks yo for your help.
almostjdmeg
Jan 3, 2009 07:41 AM
90Rexx
Mar 8, 2008 09:24 AM
SPOOLINmatt
Apr 8, 2005 12:40 PM
7rrivera7
May 24, 2003 04:29 PM
paulzy
May 21, 2002 12:33 PM
