CRX SI TRANNY
How can I tell if i got a SOHC CRX SI tranny well what I mean what is the Tranny code. I am suppose to pick one up from a friend and not sure if it a DX or SI. Well if anyone can help me out with this it will be helpfull thanks.
MIKE
MIKE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd »</TD></TR><TR><TD CLASS="quote">there is a circle that will have PL3/A??? or PL3/3000 or PL3/9000
3000 or 9000 is SI A000 or A100 is DX</TD></TR></TABLE>
i will try to see if i can see a label in my si tranny later ....its still dismounted and in my closet.....
Any way to tell what year? I'm looking for a 90-91 and I'm not sure how to tell without cracking it open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Counting the splines is the correct method
agreed
</TD></TR></TABLE>agreed
Yes but the 89-91 crx trannies all have 20 splines.. I think he is asking how to tell an 89 from a 90-91..
</TD></TR></TABLE>Yes but the 89-91 crx trannies all have 20 splines.. I think he is asking how to tell an 89 from a 90-91..
Unless he pulled it off the motor, that is the only way to figure it out that I know of.
89-91 are the same, 88 is different. Only difference between 89 and the 90-91 is the clutch disk had a smaller diameter in 89, but spline count was the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">Try the "put it in X gear and count rotations" method
best by far.</TD></TR></TABLE>
10 (number of times u spin the spline) / B - (5th gear on a Si trans) / C - (FD for Si trans) = X.XX (number of times the differential spins)
now find out what B (5th gear in a Si trans) and C (FD for Si trans) and you should get the number of times the differential spins
heres an example i did recently on a hydro Bseries, i knew it was a JDM hydro b16, but i check just in case if it was an LS..
10 (number of times u spin the spline) / .787 - (5th gear on GSR/EG SiR) / 4.4 - (FD for GSR/EG SiR) = 2.88 (number of times the differential spins)
now if it was an LS...
10 / .717 (LS 5th) / 4.266 (LS FD) = 3.2 (times the diff spins)
in the end it turned out to be a b16 tranny
For the year check the end of the input shaft for grooves going around. no groove is a 88 model, 1 groove is a 89, and 2 grooves is a 90-91. They go around the tip of the input shaft like a watch goes around your wrist.
thanks for your guys help. It helped me out a lot. Know that i found out it was a SI tranny I am going to put it in my can so i can get this grinding tranny out of my car. Grinds High RPM's in 2nd, and anytime over 3000RPM's going into 3rd, and when ever it feel like it in 4th gear. This tranny is just messed up.
MIKE
MIKE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">For the year check the end of the input shaft for grooves going around. no groove is a 88 model, 1 groove is a 89, and 2 grooves is a 90-91. They go around the tip of the input shaft like a watch goes around your wrist.</TD></TR></TABLE>
Woooo... Didnt know that one.. Thanks for the info..
ZippyZivic
16
Feb 13, 2007 11:39 AM
Chubakon
12
Jul 10, 2005 11:56 AM
CrxSi707
May 25, 2004 08:56 AM
VTECVillain
Feb 9, 2003 03:41 PM
