Picture request: Toda header (off the car)
need a picture of a toda header off the car.
i want to see the collector.
i guess the question i have is:
does the collector bolt up to a "jdm" size test pipe/cat?
my example: will my type one test pipe bolt up to the toda header using the
stock spring bolts and s2000 donut gasket?
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead »</TD></TR><TR><TD CLASS="quote">thanks!
what donut gasket is that?</TD></TR></TABLE>
It is generally accepted that the S2000 one is the easiest one to get that will fit on the Toda/JDM headers.
Unless you live closer to an Acura dealership then try hunting for a Legend donut....
the reason for this post was to make sure it fit up to my t1r test pipe
with no worries. i have all the info i need, and it will work.
thanks everyone
thanks everyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sylvain »</TD></TR><TR><TD CLASS="quote">This is a Mugen donut, but it's exactly the same as the S2000 donut. You need a JDM test pipe to fit a JDM header.
So, that means that the JDM B-pipe has the same length?
</TD></TR></TABLE>So, that means that the JDM B-pipe has the same length?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">
So, that means that the JDM B-pipe has the same length?</TD></TR></TABLE>
I never try to fit the JDM B-pipe on my setup so i can't affirm that.
No, the JDM b-pipe is significantly longer than the USDM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sylvain »</TD></TR><TR><TD CLASS="quote">You need a JDM test pipe to fit a JDM header. </TD></TR></TABLE>
I think what you meant was a 2.5" test pipe. I've never heard of a "JDM test pipe".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">
I think what you meant was a 2.5" test pipe. I've never heard of a "JDM test pipe".</TD></TR></TABLE>
I have one because i have a JDM header and a JDM B-pipe (Mugen exhaust) and if you buy a USDM test pipe it's too long.
Oh, so an Euro/USDM B-pipe would be too short then for you?
You already have a JDM B-pipe from Mugen, so that's the same length as the stock JDM B-pipe.
Spoon makes an JDM 2.5" testpipe. It won't fit on your USDM/Euro B-pipe because that Spoon testpipe is shorter.
Stinkycheezmonky
Sep 30, 2004 10:23 AM
typeRicer hater
Feb 23, 2003 05:20 PM
