Converting to obd1, what ecu should i use?
Old Oct 6, 2004 | 09:50 AM
chadmasterc's Avatar
Default Converting to obd1, what ecu should i use?
Im getting a header for my b16a, so i figure i should do it right and convert to obd1. I already know all the stuff i need to get but im unsure of what computers would work.
the computer that I know will work is the p30 out of the usdm delsol vtec, but this seems pretty rare.
will the jdm p30 work? cause ive seen a few in the classifieds.
ive also heard of the obd1 pr3. will this work?
Old Oct 6, 2004 | 09:57 AM
smart monkey's Avatar
Default Re: Converting to obd1, what ecu should i use? (chadmasterc)
yes use either a usdm or jdm/ukdm or obd1 pr3. they will all work. you can use a P28 and chip with a good P30 program. you can also convert P06(dx ecu)
Old Oct 6, 2004 | 10:34 AM
MADEINIRAQ's Avatar
Default Re: Converting to obd1, what ecu should i use? (smart monkey)
jdm p30 will work
and yes i'm selling one
Old Oct 6, 2004 | 12:30 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadmasterc &raquo;</TD></TR><TR><TD CLASS="quote">
ive also heard of the obd1 pr3. will this work? </TD></TR></TABLE>
Yes, any P30 or OBD-1 PR3 ECU (samething really) will work on your B16A if your convert to OBD-1. You can also use a chipped P28 or a P61 ECU as well, and some P06 and P08 ECUs can be chipped, but I'd stay away from a P72 or P13 for your car as they look for additional sensors that your B16 doesn't have.
Old Oct 6, 2004 | 01:56 PM
eda6's Avatar
virgin p28
Old Oct 6, 2004 | 01:59 PM
fourthgenhatchB17's Avatar
Default Re: Converting to obd1, what ecu should i use? (eda6 hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hatch &raquo;</TD></TR><TR><TD CLASS="quote">virgin p28 </TD></TR></TABLE>
You must like the lower redline
Old Oct 7, 2004 | 03:52 PM
Default Re: Converting to obd1, what ecu should i use? (MADEINIRAQ)
im looking into getting hondata down the road, wil l all of these ecu's be compatible with hondata?
Old Oct 7, 2004 | 03:58 PM
Go onto Hondata's web site. I think they got a chart that tells what ecu is compatible and works with S100,S200 etc.
Jason Nucom
Nov 20, 2013 02:43 PM
DieMaster
Apr 2, 2006 05:09 PM
92TypeR
May 3, 2004 10:02 PM
93_db2
Aug 3, 2003 08:34 PM
