where to get zc rods and pistons
Old Oct 6, 2004 | 09:46 AM
99sonicbluegsr's Avatar
Default where to get zc rods and pistons
I am about to start building my dohc obd1 zc motor. I was wonering what d series rods and pistons will work? Or are they something other than d series? and where is a good place to get them? I am wanting to boost it so I want a compression ratio somewhere around 9.0:1. Thanks for any info.
Old Oct 6, 2004 | 09:57 AM
Creepshow S60's Avatar
Default Re: where to get zc rods and pistons (99sonicbluegsr)
i think it was on homemadeturbo.com where i heard this but i'm not sure, as it was a long time ago. also, this may not be accurate, but i vaugly remember people talking about using Izuzu Rodeo or Suzuki Samurai or some type of small suv pistons.
i can't remember, i'd have to look it up...but from what i remember they fit d-series and are stronger than oem. i'm not sure if they are dished or flat though....hmmm....now i'm kinda interested in looking into this again.
Old Oct 6, 2004 | 10:26 AM
dr_latino999's Avatar
Default Re: where to get zc rods and pistons (y-49CRX)
They are the Suzuki Vitari, which are CAST pistons, not forged like everyone thinks, that drops the compression to about 8.5:1 on an A6. I think the drop though in compression would be too much in the DOHC ZC, and I would recommend that you use the stock A6 pistons.
Old Oct 6, 2004 | 11:21 AM
yellowcrx1991's Avatar
Default Re: where to get zc rods and pistons (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">They are the Suzuki Vitari, which are CAST pistons, not forged like everyone thinks, that drops the compression to about 8.5:1 on an A6. I think the drop though in compression would be too much in the DOHC ZC, and I would recommend that you use the stock A6 pistons.</TD></TR></TABLE>
I thought they were heat treated pistons and people recommened them over the stock a6 for that reason.
Old Oct 6, 2004 | 11:27 AM
DJ_SaNdOz's Avatar
For OEM replacemnet you can go w/ the 89 Teg pistons, and I am 98% sure that the rods are the same as well. I Know that teh pistons are the same cast#
Old Oct 6, 2004 | 11:50 AM
Default Re: where to get zc rods and pistons (yellowcrx1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I thought they were heat treated pistons and people recommened them over the stock a6 for that reason.</TD></TR></TABLE>
No, it is because they lower the compression and fit right in there on the stock rods.
Old Oct 6, 2004 | 11:53 AM
Also, here are some links to read up on the Vitara. I'll add them as I good.
http://www.homemadeturbo.com/f...91542
https://honda-tech.com/zerothread?id=954478
http://www.kb-silvolite.com/ar..._id=3
Old Oct 6, 2004 | 01:12 PM
So can I use aftermarket d-series rods and pistons or not? Does anyone know? Thanks for the info and keep it coming
Old Oct 6, 2004 | 03:02 PM
DJ_SaNdOz's Avatar
Yes, but you'll need to use a compression calculator to verify what the specs will need to be as it will be different in a ZC.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sonicbluegsr &raquo;</TD></TR><TR><TD CLASS="quote">So can I use aftermarket d-series rods and pistons or not? Does anyone know? Thanks for the info and keep it coming </TD></TR></TABLE>
Old Oct 6, 2004 | 08:18 PM
Default Re: where to get zc rods and pistons (DJ_SaNdOz)
Thanks for the info. I guess I am going to call race enginereing tomm. They should know, or have a really good idea about what I need to do.
burrado
Apr 15, 2015 03:53 PM
hondaluver12
Feb 17, 2009 05:51 PM
Dc2 Joe
Apr 2, 2006 07:32 PM
89civichatchback
May 2, 2003 03:51 PM
89civichatchback
May 2, 2003 12:43 PM
