Differences JDM Type R motor vs USDM Type R motor - How to identify Type R motor?
Exactly what the title says...I know of the following:
- LSD
- 2.5" collector of header
- red valve cover
- PR3 on head
- P73 on distributor
- bronze shift linkage
- dual valve spring
- JDM - B18C vs B18C5 - USDM
Anything else?
How can I identify the ITR cams?
Modified by Totalpkg at 12:55 PM 10/6/2004
Modified by Totalpkg at 1:47 PM 10/6/2004
- LSD
- red valve cover
- PR3 on head
- dual valve spring
Anything else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brol1k »</TD></TR><TR><TD CLASS="quote">you guys make the name jdm so much than it is.
All he asked were the differences, to be able to distinguish one from the other ... he not in one way, hyped up "JDM" like alot of people do ... don't post on here if you're not going contribute in any USEFUL way
</TD></TR></TABLE>All he asked were the differences, to be able to distinguish one from the other ... he not in one way, hyped up "JDM" like alot of people do ... don't post on here if you're not going contribute in any USEFUL way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">
All he asked were the differences, to be able to distinguish one from the other ... he not in one way, hyped up "JDM" like alot of people do ... don't post on here if you're not going contribute in any USEFUL way</TD></TR></TABLE>
Thank you!
Thank you!
Looks like you covered it man, but both USDM and JDM have red valve covers. But the JDM and USDM have different sized letters on DOHC and VTEC.
Also, most JDM type R motors will have a green stripe of paint on the back side of the distributor.
i thought that the b18c was a jdm gsr motor from my understanding and knowledge the tag on the motor should say b18c6 0r 7 if its a jdm that comes with 5 more horse power than the usdm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acintegragsr »</TD></TR><TR><TD CLASS="quote">i thought that the b18c was a jdm gsr motor from my understanding and knowledge the tag on the motor should say b18c6 0r 7 if its a jdm that comes with 5 more horse power than the usdm </TD></TR></TABLE>
The JDM equivelant to the GSR and Type R both come with B18C stamped on the block, so it refers to both of them. In Japan, after the the last letter, i.e. b16a, b16b, b18c, there is no number like we have on the b16a2, b18c1 and b18c5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nos51 »</TD></TR><TR><TD CLASS="quote">i think the vtec solenoid on the jdm motors do not have the oil pressure switch,and the jdm motors say b18c even if it is a type r</TD></TR></TABLE>
Good point. In fact, there is just a closed-off hole where the VTEC switch would be screwed in.
The JDM ITR motor had a 4.785 final drive. I don't remember if it got it for every year of the motor or only certain years came with that final drive.
ok.b/c you are very useful....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">Also, most JDM type R motors will have a green stripe of paint on the back side of the distributor. </TD></TR></TABLE>
I second that
here is a REALLY good thread on identify the motors - with more info
https://honda-tech.com/zerothread?id=888664
I second that
aser1z
Mar 28, 2005 05:43 PM
vtecracing2005
Mar 27, 2005 09:53 PM
B18Redline
Dec 20, 2004 12:37 AM
1993EG6
10
Dec 2, 2001 08:13 PM
Also same specs as JDM engine, but comes with a crappy exhaust (only 2" )..
