Turbo kit
The only thing that is different i think is the length of the downpipe. since the piping in 94-99 gsrs are different than the 00-01.. the 00-01 downpipe will be able an inch or so short.. it should be an easy fix. that should be the only thing different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYbRid_Eg6 »</TD></TR><TR><TD CLASS="quote">im planning to go turbo but for some reason greddy turbo kits only go to a 99 gsr, and i have a 00 gsr does it make a difference, need more info.</TD></TR></TABLE>
Blue box won't work without rewiring.
Downpipe needs modification.
However, the carb number does cover the 00 year, so it is legal.
if i were you i wouldnt put the turbo on a car that its not meanth to be on, because if there is a company defect with a part or something they wont take it back, they'll blame it on you!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevin450 »</TD></TR><TR><TD CLASS="quote">if i were you i wouldnt put the turbo on a car that its not meanth to be on, because if there is a company defect with a part or something they wont take it back, they'll blame it on you!</TD></TR></TABLE>
My man you have a lot of searching and reading you need to do. Please spend a lot in the forced induction forum.
re-wire the blue box and lengthen the downpipe.
However their kit is only CARB legal if left unmodified. The above changes should not pass smog. not to mention i think the sticker says from 96-99gsr
damn...dont listen to him
i believe the difference is in the dp.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">re-wire the blue box and lengthen the downpipe.
However their kit is only CARB legal if left unmodified. The above changes should not pass smog. not to mention i think the sticker says from 96-99gsr</TD></TR></TABLE>
someone said that it would pass smog, it covers 94 thur 00, but the kit is for 94-99 but this does not matter anyways, i live in alaska
we do have smog checks here too but ill keep it in the garage in the winter.
