Bleeding clutch lines??
Old Oct 6, 2004 | 06:43 AM
bgoetz's Avatar
Default Bleeding clutch lines??
When I bleed my clutch lines after air stops showing up in the fluid. Do I tighten the bleeder with the clutch pedal down or up?? does it matter??
Old Oct 6, 2004 | 06:58 AM
bgoetz's Avatar
Default Re: Bleeding clutch lines?? (bgoetz)
anyone??
rmcdaniels's Avatar
Down, always tighten it before you let up on the pedal or it draws air back into the line. Best way would be to use a rubber hose on the bleeder submerged in a cup of brake fluid, that way you can do it solo.
Old Oct 6, 2004 | 07:04 AM
bgoetz's Avatar
Default Re: Bleeding clutch lines?? (rmcdaniels)
That is what I thought thanks for your help
Old Oct 6, 2004 | 07:34 AM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Down, always tighten it before you let up on the pedal or it draws air back into the line. </TD></TR></TABLE>
motrayEG6
Mar 16, 2010 10:02 PM
dannycraq
Mar 18, 2008 10:45 AM
jdmh22luda
Jul 26, 2007 01:02 AM
Whig-it
Jun 21, 2004 06:21 PM
SPOONfdEK
Sep 4, 2003 10:32 PM
