Temp gauge not moving?
Old Oct 6, 2004 | 03:58 AM
HamiltonRex's Avatar
Default Temp gauge not moving?
I took my car out for the first time in 11months and everything is solid and feels good. Just the temp gauge isnt moving up.
I had the car completely gutted when i did everything. So something probably got damged.
Where should i start checking? Where is the sensor, is there a way to test the sensor with a voltmeter? What readings Should i be getting.
Thanks! The car never overheated before, just for peace of mind.
-Eric
Old Oct 6, 2004 | 05:16 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Temp gauge not moving? (HamiltonRex)
there is a wire that runs to the ecu and a sensor on one of the coolant pipes
make sure its probably just a loose wire or something like that
Old Oct 6, 2004 | 05:38 AM
Default Re: Temp gauge not moving? (MugenHonda)
below the distributor there, theres a 1 wire sensor that i have read is the coolant temp sensor.
The wire is rotted off, it is not hooked up. Could this be my reason?
Im was not getting anycodes. Maybe the car just thought it was always cold, explains why my fan never came one.
Lucky i only drove around the block a few times.
Old Oct 6, 2004 | 07:29 AM
APEX CRX's Avatar
The sensor under the distributor controls the temp gauge in the car. The one on the back of the block controls the fan coming on. Check the one on the back too.
Old Oct 6, 2004 | 08:09 AM
Default Re: Temp gauge not moving? (APEX CRX)
thanks, also a 1 wire sensor right?
Old Oct 6, 2004 | 08:47 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">thanks, also a 1 wire sensor right?</TD></TR></TABLE>
thermoswitch on back of block has 2 wires. there are bullet type connections. You'll need to pull back the rubber boot probably to check 'em
Old Oct 6, 2004 | 09:53 AM
RCautoworks's Avatar
Check the fuse first, no sense of going threw the hassle of tring to find a problem in the wiring. If its not the fuse, I would just pull out the old wiring and rewire it, probably be a lot quicker.
Old Oct 6, 2004 | 11:21 AM
Default Re: Temp gauge not moving? (90blackcrx)
The sensor below the dizzy isnt even wired up.
I might just put the fan on a manual switch.. and get an aftermarket gauge if i cant figure it out.
-Eric
Old Oct 6, 2004 | 01:32 PM
My fan isnt comming on..
Which totally sucks. Paying 449 a month for insurance cant even drive the thing.
My upper rad hose is hot, my lower is cold. Means my thermostat hasnt opened yet?
I can grab a hold of the upper rad hose and hold it, its not hot enough that i have to let go. Is the car still warming up? Because i thought coolant gets to like over boiling temp.
Thanks~!
EF_SEDAN_LOVER
Nov 20, 2014 04:06 PM
DRatedA.W.D.
18
Dec 14, 2011 10:10 AM
k.gren
12
Nov 1, 2011 09:18 AM
BlackShingo
May 20, 2010 07:36 AM
Dilly
Jan 18, 2006 10:05 PM
