VAFC causing CEL 3 (electrical MAP sensor failure)
Old Oct 5, 2004 | 11:43 PM
gutted's Avatar
Default VAFC causing CEL 3 (electrical MAP sensor failure)
ok i have a 92 gsr w/ a chipped p28 & a VAFC. first it started intermittenly that the CEL 3 would come on whenever i decel. id turn off the car then back on and it would go away. then a week ago the CEL for code 3 came back on but wouldnt go away. so i checked all connections from the VAFC & ecu harness and everything was good but the CEL for code 3 kept coming on and staying. so right now i d/c the MAP wire from the VAFC and still run the VAFC but it basically useless since i cant tune anything. anyone else have a similar prob or anything?
Old Oct 6, 2004 | 10:20 PM
gutted's Avatar
Default Re: VAFC causing CEL 3 (gutted)
bump
Old Oct 6, 2004 | 10:47 PM
Eddiebx's Avatar
probably not the cause, but did you double check to make sure the sensor is at 06 06? in the settings menu
Old Oct 7, 2004 | 08:33 AM
gutted's Avatar
Default Re: (Eddiebx)
i reconnected the MAP wire and set it to 06 06. and it was running fine for alittle bit. but then the CEL came on for MAP electrical (code 3)
Old Oct 7, 2004 | 01:06 PM
Cory man's Avatar
Default Re: (gutted)
Id hook up the map wire like stock and see if it throws a code. If it does you may actually have a bad map sensor. I know that the fields controllers are good for taking a crap after a few years. Good luck!
Old Oct 9, 2004 | 08:01 PM
gutted's Avatar
Default Re: (Cory man)
its my damn VAFC! i borrowed a friend on mines VAFC and now my car does not through any code at all. wonder if there is still a warranty on it or something
sirhatch90
10
Jun 1, 2006 04:47 PM
South Bay Surfer
Dec 24, 2004 02:15 PM
citrus3000psi
Oct 21, 2003 03:50 PM
DOHCarp
Aug 23, 2003 11:58 AM
Mugen Mike
Jun 19, 2003 09:19 AM
