where to get low temp thermostat and fan switch
yes i did a search - only one article came up w/ some part numbers...
is there anywhere online i can get a low temp thermostat and fan switch for my 89 civic si h/b?? winter is coming up, and since im a new owner to the car i figured id flush and fill my coolant to be on the safe side, and while at it change my thermostat and fan switch - only these don't seem to be that easy to find... anyone?
also - kinda stupid question, but whats the benefit of getting a spoon rad cap? ive been driving vw's and dsm's for the last 5 years and we never had problems w/ that - and last time i did own a honda (circa 1996, a 91 si h/b) there wern't even 1/10th the parts out now for them
Both Spoon and Mugen make the low temp thermostats and fan switches. You can try Options Auto Salon or eBay for these parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike Panic »</TD></TR><TR><TD CLASS="quote">also - kinda stupid question, but whats the benefit of getting a spoon rad cap? </TD></TR></TABLE>
Benefits are, you get the little spoon sticker. Don't waste your money. And let me get this straight, you want a low temp thermostat so your car heats up faster ? That will actually slow the heating up process down, stick with the stock thermostat.
i know what they do... im not a n00b to cars - i never said i wanted it to heat up faster... i just said winter was coming and i figured id flush my coolant and change the thermostat and fan switch while at it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">So whats the reason your getting a lower temp thermostat ?</TD></TR></TABLE>
lower temps don't do as much dammage to motors as higher temps do...
lower temps don't do as much dammage to motors as higher temps do...</TD></TR></TABLE>
True to a point, an engine that takes longer to get to operating temps is not good also. If your engine is running the correct temp to began with there is no reason to lower it. I'm not gonna start a debate about why which one is better since you said your not a noob.
a low temp thermostat does not affect how long it will take a car to warm up....it will simply regulate the temp lower when the car does get warmed up..
Spoon Rad caps are set to release at a higher pressure then stock..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">a low temp thermostat does not affect how long it will take a car to warm up
Depends on how low the thermostat temp is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">all the ones I have seen are about 10-20 degrees lower then a stock one..
have you seen differently?</TD></TR></TABLE>
Yes
Yes
alanvtec
Feb 25, 2014 01:23 PM
aleks77
May 30, 2008 07:57 PM
AntMan401
Aug 23, 2006 05:08 AM
sir91
Sep 1, 2003 08:38 PM
