BUILT H22 complete swap for sale
Old Oct 5, 2004 | 08:35 PM
slthatch's Avatar
Default BUILT H22 complete swap for sale
the crank was just remachined by bokan brothers, with new rod and main bearings put in. Has all new jaskets complete top to bottom with all new belts timing, alternator, balance shaftbelt. The motor has type s pistons, rings, & rods 11 to 1 compression, brand new stock clutch and flywheel, unorthodox lightwieght pulley red. Ported and polished head, intake manifold, throtle body. Skunk 2 valves retainrs and dual valve springs, str cam gears, OBX headers, ecu with mugen chip for 5500 vtec kicks in and 9200 rpm limit. After market mallary coil. the motor is complete with wiring harness, ecu, tranny, shift linkage, starter, distrubuter, fuel rail, and motor mounts for 92-95 honda civic. All the motor needs is fuel injectors cause the ones i have are h23 and sputtor at vtec, and the valves are bent on the intake side but other than that complete for any car as long as you have the right motor mounts. call with question 775-291-8735, or email at liltroy012003@aol.com looking to get $2500 or trades call or email.
Modified by Losthorizon84 at 6:12 AM 10/6/2004
Old Oct 5, 2004 | 08:40 PM
slthatch's Avatar
Default Re: BUILT H22 complete swap for sale (Losthorizon84)
bump back to the top for one fast *** moving thread
Old Oct 5, 2004 | 09:01 PM
slthatch's Avatar
once again bump it to the top
Old Oct 5, 2004 | 09:09 PM
slthatch's Avatar
can i get a bump?
Old Oct 5, 2004 | 10:06 PM
slthatch's Avatar
can i get a bump bump
Old Oct 5, 2004 | 10:28 PM
slthatch's Avatar
bump
Old Oct 6, 2004 | 07:11 PM
slthatch's Avatar
bump back to page 1 from 37 WOW
Old Oct 6, 2004 | 07:12 PM
Maddox's Avatar
stock sleeves?
Old Oct 6, 2004 | 07:20 PM
slthatch's Avatar
yes stock sleeves
Old Oct 7, 2004 | 07:22 AM
skunked's Avatar
Default Re: (Losthorizon84)
PM'd
Old Oct 14, 2004 | 06:52 AM
slthatch's Avatar
bump get it to the top for one day i will have a buyer
Old Oct 19, 2004 | 12:24 AM
rovigian's Avatar
Does this include tranny?
I am looking for a project swap for my stripped 94 ls. good swap cantidate?
Old Oct 19, 2004 | 07:41 AM
skunked's Avatar
Default Re: BUILT H22 complete swap for sale (rovigian)
yes it has the tranny.
Old Oct 19, 2004 | 08:35 AM
rovigian's Avatar
Default Re: BUILT H22 complete swap for sale (skunked)
How much would it cost to crate, or would I have to pickup locally, also, are you including the cable shifter assembly. What motor mounts do you have for it right now?
BrianSi91
Dec 18, 2007 05:01 AM
n1_egsex
Northern California (Sales)
Nov 15, 2007 11:57 AM
88crxsir
May 2, 2004 11:28 PM
2.2L EH2
25
Jun 25, 2002 07:56 PM
