Rebuild time!
Old Oct 5, 2004 | 07:51 PM
STS_Underdog's Avatar
Default Rebuild time!
I'm planning to rebuild my stock D16A6 bottom end and need some advice on what needs to be replaced. I've got a bottom end of unknown mileage and I figure it's smarter to go ahead and do some things before I get it in the car and have troubles. I'm planning to replace the rings and check rod/ main bearing clearances and replace as needed. What gaskets should I order? Do the thrust washers need to be replaced? I'm also going to do the clutch while I'm there with new pressure plate, throwout bearing, and pilot bearing. Any other suggestions? TIA!
Old Oct 5, 2004 | 07:57 PM
Bandit74's Avatar
Any gasket that is pulled off, replace it with a new one.
Old Oct 5, 2004 | 08:14 PM
Default Re: (Bandit74)
Thing is I'm doing it this weekend so I'd like to have everything I need before I pull it apart. Suggestions?
DanielP
10
Aug 25, 2017 10:33 AM
StockDC2
Honda Civic (2001 - 2005)
Jul 8, 2017 01:59 AM
TurboEG600
Apr 2, 2013 03:26 PM
dem0nk1d
Oct 10, 2012 06:40 AM
na96ek4
Sep 25, 2006 06:14 PM
