B18B1/B20 cams - same or different?
Old Oct 5, 2004 | 07:35 PM
goodfella732's Avatar
Default B18B1/B20 cams - same or different?
I have someone wanting to sell me B20 cams. Is there any difference from the stock LS cams? I was told it will give me alittle bit better top end. I dont want to waste money on them if they are the same.
Old Oct 5, 2004 | 07:51 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: B18B1/B20 cams - same or different? (goodfella732)
Get a set of crowers instead..
Old Oct 5, 2004 | 07:55 PM
opkjoblacsh's Avatar
Default Re: B18B1/B20 cams - same or different? (LSVTEC 91 Civic)
b20b's power is in the lower rpm range that wouldnt make any sense for them to give your high revving b18c1 anymore topend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Get a set of crowers instead.. </TD></TR></TABLE>
i second that...
Old Oct 5, 2004 | 08:10 PM
Default Re: B18B1/B20 cams - same or different? (opkjoblacsh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opkjoblacsh &raquo;</TD></TR><TR><TD CLASS="quote">b20b's power is in the lower rpm range that wouldnt make any sense for them to give your high revving b18c1 anymore topend
Guess you didnt read the title. I have a LS motor in the car.
StyleTEG's Avatar
The B18B cams have slightly more duration.
The B20 cams would lower top end.
Old Oct 5, 2004 | 08:13 PM
Default Re: B18B1/B20 cams - same or different? (StyleTEG)
so I would end up doing more harm then good?
Old Oct 6, 2004 | 03:28 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodfella732 &raquo;</TD></TR><TR><TD CLASS="quote">so I would end up doing more harm then good?</TD></TR></TABLE>
Not necessarily. Your Powerband just may be lower than w/ the LS cams. IMO, I would rahter have the powerband be a little higher because even w/ my LS tranny I pass the traps @ 7100 in 4th.
blkb18
Oct 9, 2006 04:02 PM
sycamore
Aug 19, 2005 03:37 PM
drudy
Feb 16, 2005 07:34 PM
kinvid22
Jan 10, 2004 12:02 PM
StorminMatt
23
Nov 6, 2003 01:54 PM
