year of the block?
Old Dec 14, 2001 | 08:39 AM
B_CRUZ!'s Avatar
Default year of the block?
how can i tell what year the short block is? i am buying a shorty from a engine dist. place and i don't think they have any clue as to what year the block is from. oh BTW its a b16a. i know that if its stamped B16A with no number after then its jdm. but is there a way to tell if it is the 10.2 or 10.4 cr just by looking at it.
T|I|A
Old Dec 14, 2001 | 09:31 AM
B_CRUZ!'s Avatar
Default Re: year of the block? (eg6_inspired)
i did a search and everything.
Old Dec 14, 2001 | 10:35 AM
B18C-EJ1
Guest
Posts: n/a
By the engine number.
1xxxxxx is the 1st gen
5xxxxxx is the 2nd gen
Old Dec 14, 2001 | 12:36 PM
B_CRUZ!'s Avatar
Default Re: year of the block? (B18C-EJ1)
i thought that meant 1 came off an XSi and 5 came off of a SiR. or the other way around. well does any body have a 2nd gen JDM B16A? can you tell me the first digit of your block number?
thanx
Old Dec 14, 2001 | 02:37 PM
90accord1's Avatar
1 and 5 does not designate 1st or second gen. as i have both a 1xx 2nd gen and a 5xx 2nd gen in my garage at the moment, the only way to tell if its going to be a 91.5 and up block or not is by the pistons and if you look on http://tiiite.b16a.com
somewher eunder specnicly speaking you should see pics of the different pistons in the blocks and which one your specificly looking for.
Old Dec 15, 2001 | 07:36 AM
92Hatcher's Avatar
Default Re: year of the block? (90accord1)
For a JDM ITR (B18C) swap, how do you tell what is year of motor?
Is the date of manufacture located somewhere on the block?
Old Dec 15, 2001 | 10:08 AM
WOLFPACK's Avatar
Default Re: year of the block? (92Hatcher)
The date will be stamped on the head just above the header, in a little circle with an X through it... If you don't have the head you could trace the date by using the serial #'s, at least I think you can
deeb_xiong
May 19, 2014 07:02 AM
dommyy13
Sep 27, 2012 12:18 PM
T3k C
Dec 4, 2005 05:38 PM
sol2nr
Apr 13, 2004 11:07 PM
