need advice $4000-5000 budget
Old Oct 5, 2004 | 03:04 PM
rafiq7's Avatar
Default need advice $4000-5000 budget
this is what i have so far
ls block, stock rods b16a pistons, micropolished stock crank
b16 head, stock, ITR intake manifold, RC 310 injectors, GSR ECU, GSR distibutor, B16 oil pump
the other thing is, this is a daily driver, I live in phoenix, AZ and it gets 120 here during the summer time,
Old Oct 5, 2004 | 03:07 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: need advice $4000-5000 budget (rafiq7)
sooooo, what is your question? Anything in particular? maybe suspension or something,unless you already have it. We can offer advice on anything, as long as what we are being asked to offer advice on.
Old Oct 5, 2004 | 03:10 PM
rafiq7's Avatar
Default Re: need advice $4000-5000 budget (marsbike)
i would like to modify my engine.
upgrade to a b20 or get a stroker kit,
but keep it reliable,
sorry for not being detailed.
one thing i will do for sure is get skunk2 stage 2cams
Old Oct 5, 2004 | 03:27 PM
rafiq7's Avatar
crower does make a stroker kit for 2000, and it pushes displacement up to 2.2.
what you think guys? is it safe?
Old Oct 5, 2004 | 04:03 PM
shamoo's Avatar
Will you make something up for me please?
Quite obvious.....
Build it and turbo it. Big boost.
Old Oct 5, 2004 | 04:11 PM
Copy Cat's Avatar
Default Re: need advice $4000-5000 budget (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Quite obvious.....
Build it and turbo it. Big boost. </TD></TR></TABLE>
**** yea shamoo is right. You can build a perfectly reliable turbo set up with that kind of money. Sell some of your stuff and start over man. Get 440 injectors, hondata, good manifold, etc, etc, and boost her. Now if your heart is set on all motor then by all means go for it. For your 4k-5k allowance i would say boost would be the best bang for the buck.
Old Oct 5, 2004 | 04:19 PM
GS-Rdriven's Avatar
Default Re: need advice $4000-5000 budget (CivicFerioViRs)
suspension/handling-shocks springs strut/sway/tower bars and the rest on engine/performance and tuning IMO
Old Oct 5, 2004 | 05:29 PM
Kendall's Avatar
I would have the engine balanced before I did anything, then I'd look at systematically upgrading the car based on what exactly you want. In your case, it probably wouldn't be a bad idea to invest in a thicker aluminum radiator and some stronger fans. In fact go ahead and get a GSR water pump as well (better safe than sorry).
If your looking at a general performance standpoint, I'd look into some mild suspension upgrades and a good set of tires. I'd also invest in a "quality" header and exhaust setup. What tranny do you have? If it's an LS, then have you thought about going to a B16 tranny? What about getting an LSD, or traction bars?
There are a lot of available options. Set a goal and work towards it.
Old Oct 5, 2004 | 06:21 PM
:jdmshmaydm:'s Avatar
Fast and reliable with that budget? Sell what you have now then take the money you already have and go K20.
Old Oct 10, 2004 | 03:36 PM
rafiq7's Avatar
Default Re: (Kendall)
i have a gsr tranny,
ls water pump,
b16 oil pump.
greddy sp2 header.
Old Oct 10, 2004 | 03:37 PM
rafiq7's Avatar
Default Re: need advice $4000-5000 budget (Gatecrasher20AF)
k20? hmmmm
always an option, any negatives in doing this?
ral24_hct
Aug 24, 2009 09:38 PM
shocker911
Oct 27, 2008 12:55 PM
specoperformance
Aug 7, 2008 02:14 PM
98lsskunk
Feb 28, 2005 03:15 PM
