96 civic with integra supsension question
i got a 96 civic i got the whole suspension from inegra front and rear and the master cylinder
i am gone put the master cyclinder on and get a porportioning valve from si
can some one show me what parts i use from the integra suspension i got for front and rear thansk
also what energy suspension kit do i use i want to do those before i put it in thanks guys
also can i just put the typer hubs on the 4 lug suspension thanks guys
uh what part of the integra suspension did you get? jsut teh shocks and springs? or the control arms as well? Assuming its just the shocks and springs The fronts should bolt right in. the rears require the integra LCA I believe.
If you wanto go 5 lug from a type R. you need to replace the entire fork and more I think. Its all different. Oh plus the drive shafts are different. the type R are bigger so I think you need to buy those too. Aks people who have done 5 lug conversions.
i got both lower arms from both and upper arms from front eveything but need to know what to use from e each for each side front and back and the other questions thansk
you dont need to change the prop valve when adding disc brakes to an ek hatch. they have the same prop valve as 99-00 si's (also 4 wheel disc). also, you can't use the rear LCA's off a teg. they're the wrong size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-cRx »</TD></TR><TR><TD CLASS="quote">i got both lower arms from both and upper arms from front eveything but need to know what to use from e each for each side front and back and the other questions thansk </TD></TR></TABLE>
did you get the brakes too?
JDMorgan
Mar 21, 2005 04:11 AM
