Type-R tranny guts in GSR case?
Old Oct 5, 2004 | 10:32 AM
Andy M's Avatar
Default Type-R tranny guts in GSR case?
Is is possible to install the internals from an itr transmission in a gsr transmission case? I have a type-r transmission with a hole worn through the case inside the bell-housing (clutch exploded), and a gsr transmission with bad bearing or bearings.
Can the parts from both be turned into a working transmission? If so, are there any parts which will need replacement?
Thanks
Old Oct 6, 2004 | 08:25 AM
Andy M's Avatar
Default Re: Type-R tranny guts in GSR case? (jazzman)
Only going to bump this once...
Old Oct 6, 2004 | 08:29 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazzman &raquo;</TD></TR><TR><TD CLASS="quote">Only going to bump this once...</TD></TR></TABLE>
dont get mad now...
it will fit just fine, as far as replacing...well you need to replace the parts that are broken
Old Oct 6, 2004 | 11:58 AM
93lsd's Avatar
yes everything will work, you and even just use the lower case if you wanna
Old Oct 6, 2004 | 12:11 PM
Andy M's Avatar
Default Re: (93lsd)
Thanks guys! That's good to know. I think I'm going to just order a new lower case for about $400, fix both transmissions, and sell my gsr tranny, hopefully for more than ~$400.
I wasn't mad, but rather just pointing out that I wasn't going to bump the thread again.
Old Oct 6, 2004 | 03:23 PM
93lsd's Avatar
Default Re: (jazzman)
if you need a lower case i have one for a gsr..
akces
Feb 28, 2011 05:51 PM
gonebrokeboost21
Jun 26, 2010 08:06 PM
Sleek98
Dec 5, 2004 06:24 PM
eight grand
May 25, 2003 08:57 AM
vtecsdn
Nov 19, 2002 06:28 PM
